Building RTEMS tools using Source Builder fails
Thu Oct 5 11:02:25 UTC 2017
On 05/10/17 12:13, Steen Ulrik Palm wrote:
> Looking in the file
> rsb-report-sparc-rtems4.12-gdb-8.0.1-x86_64-linux-gnu-1.txt shows that
> the configure command complains about python2.7:
> checking for XML_StopParser... yes
> checking whether to use python... yes
> checking for python... /usr/bin/python
> configure: error: python is missing or unusable
> checking for python2.7... no
> Two questions:
> 1.Is this a known issue?
I think you need the python-devel package installed.
> 2.Is it possible to proceed without having to rebuild already
> installed tools (like newlib, which takes very long time to build)?
Unfortunately not at the moment.
> I have also tried to use released versions of the Source Builder
> (4.11.1 and 4.11.2). When using these versions, the building of newlib
> fails because gcc cannot find zlib.h included by one of the source files.
For this you need the zlib-devel package.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
