Building RTEMS tools using Source Builder fails
Thu Oct 5 13:35:30 UTC 2017
On 05/10/17 15:29, Steen Ulrik Palm wrote:
> Thanks a lot for spotting the problem:-)
I just created a new one for you...
> After having installed python2.7-dev, I have now successfully built the RTEMS tools.
... if you use RTEMS 4.12, then you should immediately update the RSB
and RTEMS and build it again.
https://lists.rtems.org/pipermail/devel/2017-October/019121.html
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
