Installing cexp-2.2.3 for RTEMS 4.12
    Akiv
    akivjh at gmail.com
    Thu Oct  5 21:06:13 UTC 2017
Hi All,
I have built RTEMS 4.12 for the pc686 BSP. I am now trying to install cexp
2.2.3. My goal is to run pc-rtems according to this guide:
https://github.com/nasa/cFE/tree/master/psp/fsw/pc-rtems.
After configuring, when I run the make I get the following error.
bash-4.1$ ../cexp-CEXP_Release_2_2_3/configure --with-rtems-top=/home/rtems/
pc_rtems/development/rtems/4.12 --host=i386-rtems4.12
--enable-std-rtems-installdirs
bash-4.1$ make -j 8
make  all-recursive
make[1]: Entering directory `/home/rtems/pc_rtems/
development/rtems/kernel/b-cexp'
Making all in pc686
make[2]: Entering directory `/home/rtems/pc_rtems/
development/rtems/kernel/b-cexp/pc686'
make  all-recursive
make[3]: Entering directory `/home/rtems/pc_rtems/
Making all in regexp
make[4]: Entering directory `/home/rtems/pc_rtems/
development/rtems/kernel/b-cexp/pc686/regexp'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/rtems/pc_rtems/development/rtems/kernel/b-
cexp/pc686/regexp'
Making all in libtecla
development/rtems/kernel/b-cexp/pc686/libtecla'
i386-rtems4.12-gcc
-B/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/pc686/lib/
-specs bsp_specs -qrtems  -B /home/rtems/pc_rtems/
development/rtems/4.12/i386-rtems4.12/lib -mtune=pentiumpro -march=pentium
 -I/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/pc686/lib/include
-I/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include
-DPACKAGE_NAME=\"\" -DPACKAGE_TARNAME=\"\" -DPACKAGE_VERSION=\"\"
-DPACKAGE_STRING=\"\" -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\"
-DPACKAGE=\"libtecla\" -DVERSION=\"1.0\" -DSTDC_HEADERS=1
-DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
-DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1
-DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_SELECT_H=1 -DHAVE_SELECT=1
-I. -I../..//../cexp-CEXP_Release_2_2_3/libtecla
-I../..//../cexp-CEXP_Release_2_2_3/libtecla/.. -DPACKAGE_NAME=\"\"
-DPACKAGE_TARNAME=\"\" -DPACKAGE_VERSION=\"\" -DPACKAGE_STRING=\"\"
-DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\" -DPACKAGE=\"libtecla\"
-DVERSION=\"1.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1
-DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
-DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1
-DHAVE_SYS_SELECT_H=1 -DHAVE_SELECT=1    -MT libtecla_a-getline.o -MD -MP
-MF .deps/libtecla_a-getline.Tpo -c -o libtecla_a-getline.o `test -f
'getline.c' || echo '../..//../cexp-CEXP_Release_2_2_3/libtecla/'`getline.c
i386-rtems4.12-gcc
-I../..//../cexp-CEXP_Release_2_2_3/libtecla/.. -D_POSIX_C_SOURCE=199506L
-DPREFER_REENTRANT    -MT libtecla_r_a-getline.o -MD -MP -MF
.deps/libtecla_r_a-getline.Tpo -c -o libtecla_r_a-getline.o `test -f
In file included from ../..//../cexp-CEXP_Release_2_
2_3/libtecla/getline.c:154:0:
../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:60:2: error:
#error "This file is deprecated; remove this line if you absolutely have to
use it"
to use it"
../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:62:8: error:
redefinition of 'struct winsize'
 struct winsize {
In file included from /home/rtems/pc_rtems/development/rtems/4.12/i386-
rtems4.12/include/sys/ioctl.h:49:0,
2_3/libtecla/getline.c:59:
rtems4.12/include/sys/ttycom.h:52:8: note: originally defined here
 struct winsize {
../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:74:0:
warning: "IOCPARM_MASK" redefined
 #define IOCPARM_MASK 0x1fff  /* parameter length, at most 13 bits */
rtems4.12/include/sys/ioctl.h:45:0,
rtems4.12/include/sys/ioccom.h:47:0: note: this is the location of the
previous definition
 #define IOCPARM_MASK ((1 << IOCPARM_SHIFT) - 1) /* parameter length mask */
../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:76:0:
warning: "_IOC" redefined
 #define _IOC(inout,group,num,len) (inout | ((len & IOCPARM_MASK) << 16) |
((group) << 8) | (num))
rtems4.12/include/sys/ioccom.h:59:0: note: this is the location of the
previous definition
 #define _IOC(inout,group,num,len)     \
use it"
to use it"
 struct winsize {
 struct winsize {
previous definition
previous definition
make[4]: *** [libtecla_r_a-getline.o] Error 1
make[4]: *** Waiting for unfinished jobs....
make[4]: *** [libtecla_a-getline.o] Error 1
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/rtems/pc_rtems/development/rtems/kernel/b-
cexp/pc686'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/home/rtems/pc_rtems/development/rtems/kernel/b-
cexp/pc686'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/rtems/pc_rtems/development/rtems/kernel/b-
cexp'
make: *** [all] Error 2
Would someone be able to provide some insight?
Best Regards,
Akiv Jhirad
URL: <http://lists.rtems.org/pipermail/users/attachments/20171005/745d5efd/attachment-0001.html>
