HTTP client with RTEMS
Hui Yie Teh
hteh703 at aucklanduni.ac.nz
Fri Oct 6 12:33:26 UTC 2017
Hi Christian,
No, it's not an RTEMS based server. I have a simple server running on
python.
I am emulating the LM3S6965 ARM board on Qemu, and I think it has 64kB of
RAM?
On 6 October 2017 at 19:52, Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Am 05.10.2017 um 22:44 schrieb Hui Yie Teh:
> > I'm trying to initialize bsdnetwork using
> > 'rtems_bsdnet_initialize_network()' as in the mghttpd example but it
> > doesn't work.
> > It is giving me an error "Can't get network cluster memory".
> > Any help would be much appreciated.
> > Thanks.
> > On 6 October 2017 at 08:46, Hui Yie Teh <hteh703 at aucklanduni.ac.nz
> > <mailto:hteh703 at aucklanduni.ac.nz>> wrote:
> > Hi Christian,
> > Thank you for the reply!
> > My app will be doing some simple HTTP, with GET and POST requests
> > that has a text response body, e.g. "Received". I think following
> > the mghttpd test will suffice.
> > However, I'm currently looking at the code for the mghttpd test and
> > I was wondering if there is a way I can run it or get a non-test
> > version of it? I can't really tell what I need or what the code does
> > without running it.
> > Cheers.
> > On 6 October 2017 at 07:47, Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > Am 05.10.2017 um 17:52 schrieb Hui Yie Teh:
> > > Hi,
> > > I am trying to build a HTTP client using RTEMS. Is there any
> > tutorials
> > > that I can follow? I already have a server running, and I just
> > need to
> > > send some GET and POST requests.
> > > I am new to RTEMS and embedded programming in general. Any
> > help is much
> > > appreciated.
> > > Cheers,
> > > Yie
> > Hello Yie,
> > it depends a little on your application.
> > If you just want to learn a little about the HTTP protocol and
> > only want
> > to try some requests, you can just use a raw socket. The HTTP
> > basics are
> > really quite simple if you don't want to use things like
> > compression or
> > different MIME types. Writing a simple request for some simple
> html
> > document is quite easy. Something like that is done in the test
> > for the
> > mghttpd in RTEMS:
> > https://git.rtems.org/rtems/tree/testsuites/libtests/mghttpd01
> > <https://git.rtems.org/rtems/tree/testsuites/libtests/mghttpd01>
> > Note that there are most likely a lot of error cases that are
> > not caught
> > in that test (like unexpected HTTP responses).
> > If you need your client for some more professional application or
> > something that should be more robust, I would suggest to use some
> > library that does most of the low level handling. I'm not aware
> > of one
> > integrated into RTEMS but it shouldn't be hard to find one that
> > works.
> > I think that I have seen some client functions in civetweb (still
> > MIT-licensed fork of mongoose httpd which has been forked off
> > before the
> > license change in mongoose). From my experience, civetweb needs
> only
> > very few modifications to work with RTEMS.
> > Most likely you can also (with some more effort) compile some
> > bigger C
> > or C++ libraries like libcurl. But I haven't tried that yet. By
> > the way:
> > there is also a large list of http client libraries on the
> libcurl
> > Homepage: https://curl.haxx.se/libcurl/competitors.html
> > <https://curl.haxx.se/libcurl/competitors.html>
> > Regards
> > Christian
> Hello Yie,
> you said in your initial mail that you already have a server running. Is
> that an RTEMS based server? In that case I would suggest to just use the
> initialization from that one.
> The "Can't get network cluster memory" is printed if a malloc for a
> cluster of mbufs fails in the initialization. A possible reason for that
> is that there isn't enough memory. On what platform are you working? How
> many RAM do you have?
> Regards
> Christian
> embedded brains GmbH
> Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/users/attachments/20171007/c2aedb31/attachment.html>
