Filesystem in RTEMS
xuelin.tian at qkmtech.com
Sat Oct 21 03:58:12 UTC 2017
> $ arm-rtems4.12-nm \
> /opt/rtems/4.12/arm-rtems4.12/xilinx_zynq_zc706/lib/libjffs2.a | \
> grep rtems_jffs2_compressor_zlib_compress
> 00000000 T rtems_jffs2_compressor_zlib_compress
I checked the symbols, same result as yours.
>> I also add this library -
>> "additional_flags += ['-L/opt/rtems-4.11.1-release/4.11-bsp/arm-rtems4.11/xilinx_zynq_zedboard/lib -ljffs2']"
>Link order?
Yeah, I google it, and it says that this kind of error is related to linking order. But I use waf, and have no idea how to change the order...
bld.program(target = "bkv01.elf",
features = "cprogram",
cflags = system_flags,
includes = system_includes,
source = system_src,
use = ["bsd"],
lib = ["m", "z"],
install_path = None
So I just delete the compressor & decompressor part, and run it.
In the function "mount_and_make_target_path", the "rtems_mkdir" part works well, but the "mount" process takes a long time, and no return...
I can not debug the mount process, since it is a system call.
Best wishes,
Date: 2017-10-21 11:40
To: xuelin.tian at qkmtech.com; Sebastian Huber; users at rtems.org
Subject: Re: Filesystem in RTEMS
On 21/10/2017 13:13, xuelin.tian at qkmtech.com wrote:
> All these three functions should be defined in libjffs2.a, right?
Yeap ...
Link order?
URL: <http://lists.rtems.org/pipermail/users/attachments/20171021/1f7fd444/attachment.html>
