Filesystem in RTEMS
    Sebastian Huber
    Mon Oct 23 09:40:38 UTC 2017
On 23/10/17 11:33, xuelin.tian at qkmtech.com wrote:
> static int flash_write(
>     rtems_jffs2_flash_control *super,
>     uint32_t offset,
>     unsigned char *buffer,
>     size_t length) {
>     flash_control *self = get_flash_control(super);
>     XQspiPs *flash_handle = self->flash_instance;
>     uint32_t num = length / S25FL256S_PAGE_SIZE;
>     uint32_t remaining = length % S25FL256S_PAGE_SIZE;
>     uint32_t written;
>     for (written = 0; written < num; written++) {
>         FlashWrite(flash_handle, beginning + written*S25FL256S_PAGE_SIZE, \
>             S25FL256S_PAGE_SIZE, WRITE_CMD, \
>             buffer + written*S25FL256S_PAGE_SIZE);
>     if (remaining) {
>         FlashWrite(flash_handle, beginning + num*S25FL256S_PAGE_SIZE, \
>             remaining, WRITE_CMD, buffer + num*S25FL256S_PAGE_SIZE);
>     return S25FL256S_SUCCESS;
> where, my FlashRead and FlashWrite functions will invoke the functions
> defined in Xilinx BSP to transfer data from/into flash.
> I do not know where the problem is...
You assume length % S25FL256S_PAGE_SIZE == 0.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
