Filesystem in RTEMS
Russell Haley
russ.haley at gmail.com
Tue Oct 24 16:09:22 UTC 2017
FreeBSD doesn't have a flash filesystem that I know of, so at one point I
looked into porting CHFS over:
http://chewiefs.sed.hu/
I'm not sure if it still lacks NOR support. FreeBSD, however, doesn't have
flash drivers to support a file system yet. The support it currently has
isn't viable as the error correction code is too rudimentary.
Russ
On Tue, Oct 24, 2017 at 9:01 AM, Russell Haley <russ.haley at gmail.com> wrote:
> On Mon, Oct 23, 2017 at 11:42 AM, Joel Sherrill <joel at rtems.org> wrote:
>> On Mon, Oct 23, 2017 at 10:37 AM, Russell Haley <russ.haley at gmail.com>
>> wrote:
>>> Hi,
>>> Just wanted to ask about licensing. Jffs2 is expressly GPL code. My
>>> understanding means that the entirety of your work now becomes GPL licensed
>>> because everything is statically linked together in RTEMS. Is this
>>> understanding incorrect?
>> It is GPLv2 with a linking exception like the GCC language run-times used
>> to use. See
>> https://github.com/atgreen/RTEMS/blob/master/LICENSE.JFFS2
>> and read the last two paragraphs.
>> --joel
> Thanks Joel!
> Russ
>>> Thanks,
>>> Russ
>>> Sent from my BlackBerry 10 smartphone on the Virgin Mobile network.
>>> *From: *jameszxj
>>> *Sent: *Monday, October 23, 2017 12:13 AM
>>> *To: *rtems-users at rtems.org
>>> *Subject: *Re: Filesystem in RTEMS
>>> I have encountered a problem like this.
>>> I set wrong block size.
>>> Maybe you can try to change the block size.
>>> I use jffs2 on xilinx zc7020 board, QSPI
>>> ------------------ Original ------------------
>>> *From: * "Sebastian Huber";<sebastian.huber at embedded-brains.de>;
>>> *Date: * Mon, Oct 23, 2017 01:07 PM
>>> *To: * "xuelin.tian at qkmtech.com"<xuelin.tian at qkmtech.com>;
>>> *Cc: * "users at rtems.org"<users at rtems.org>;
>>> *Subject: * Re: Filesystem in RTEMS
>>> On 22/10/17 12:00, xuelin.tian at qkmtech.com wrote:
>>> > I have mounted JFFS2 successfully, according to the return value.
>>> > Yes, it takes some time to do the mounting work.
>>> > But, when I downloaded a file like "test.txt" into flash via FTP and
>>> > restarted the system, error came up.
>>> Unmount the file system before you restart the system.
>>> > <5>JFFS2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not
>>> found at 0x01FC0028: 0xE5DF instead
>>> found at 0x01FC002C: 0xE5DF instead
>>> > <5>JFFS2: Further such events for this erase block will not be printed
>>> found at 0x01FD0000: 0x000C instead
>>> found at 0x01FD0004: 0xB0B1 instead
>>> found at 0x01FD0008: 0x0054 instead
>>> > <5>JFFS2: Cowardly refusing to erase blocks on filesystem wi
>>> th no valid JFFS2 nodes
>>> > <5>JFFS2: empty_blocks 0, bad_blocks 0, c->nr_blocks 510
>>> > mount failed.
>>> > Everything worked well, after erasing the whole flash. But errors came
>>> > up without erasing it.
>>> Make sure your flash driver works correctly. It must support bytewise
>>> programming.
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4
>>> <https://maps.google.com/?q=Dornierstr.+4&entry=gmail&source=g>,
>>> D-82178 Puchheim, Germany
>>> Phone : +49 89 189 47 41-16
>>> Fax : +49 89 189 47 41-09
>>> E-Mail : sebastian.huber at embedded-brains.de
>>> PGP : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
>>> users mailing list
>>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20171024/87b3bfce/attachment.html>
