Building RTEMS 4.12 for ARM using source builder fails
Brendan McNally brendan at xia.com
Thu Oct 26 17:21:42 UTC 2017
Hello -
Noob here, attempting to build RTEMS tools using the Source Builder for the
ARM architecture. I'm hoping someone can steer me straight. Here's the
rundown:
Host:
Win10pro x64, using MSYS2 (20161025).
sb-check identified some early problems with my python installation. I had
originally installed Python 3.6.3 for windows from python.org, then -- when
that was unsuccessful (complained about .startswith() args) -- rolled back
to 2.7.14, also from python.org. This was also unsuccessful; sb-check
reported issues with host config. Uninstalled both of these, and installed
mingw64/python2 from msys2, per comments in source-builder/sb/windows.py,
and that allwed sb-check to complete successfully. Well, with one warning
about SVN.
     warning: exe: absolute exe found in path: (__svn) /usr/bin/svn
I attempt to build the tools using the following command:
    ../source-builder/sb-set-builder --log=l-arm.txt \
--prefix=$HOME/development/rtems/4.12 4.12/rtems-arm
and it fails building newlib with the following info:
   config: tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg
   package:
arm-rtems4.12-gcc-7.2.0-newlib-2.5.0.20170922-x86_64-w64-mingw32-1
   building:
   error: building arg7n2xwm1
   Build FAILED
     See error report:
rsb-report-arm-rtems4.12-gcc-7.2.0-newlib-2.5.0.20170922-x86_64-w64-mingw32-1.txt
I also tried building with the additional flag --jobs=none, and receive the
same error.
Looking in the report, it's complaining about an include file that cannot
be located.
In file included from
../../../../../../../../../../gcc-7.2.0/newlib/libm/machine/arm/s_ceil.c:39:0:
../../../../../../../../../../gcc-7.2.0/newlib/libm/machine/arm/../../math/s_ceil.c:23:10:
fatal error: fdlibm.h: No such file or directory
 #include "fdlibm.h"
compilation terminated.
Full report is attached.
Thanks in advance,
Brendan
URL: <http://lists.rtems.org/pipermail/users/attachments/20171026/266a6737/attachment.html>
Name: rsb-report-arm-rtems4.12-gcc-7.2.0-newlib-2.5.0.20170922-x86_64-w64-mingw32-1.zip
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20171026/266a6737/attachment.bin>
