Building RTEMS 4.12 for ARM using source builder fails
Joel Sherrill
joel at rtems.org
Mon Oct 30 17:50:45 UTC 2017
On Oct 30, 2017 1:33 PM, "Brendan McNally" <brendan at xia.com> wrote:
Hi Chris -
Thank you! The path length was indeed the issue, and building from
'E:\dev\rtems' worked as advertisied.
And thank you for directing me to the user manual documentation. I had
inadvertently started my journey using a different documentation set; the
RTEMS Source builder docs (https://docs.rtems.org/
branches/master/rsb/index.html).
Glad you got it built.
Chris... Does it make sense to check for a starting path on Windows that is
too long? This is such an easy situation to trip across and it seems to
fail in mysterious ways.
--joel
Thanks again!
Brendan
On Thu, Oct 26, 2017 at 7:16 PM Chris Johns <chrisj at rtems.org> wrote:
> On 27/10/2017 04:21, Brendan McNally wrote:
> > Hello -
> > Noob here, attempting to build RTEMS tools using the Source Builder for
> the ARM
> > architecture.
> Welcome.
> > I'm hoping someone can steer me straight.
> It is looking pretty good.
> > Here's the rundown:
> > Host:
> > Win10pro x64, using MSYS2 (20161025).
> > sb-check identified some early problems with my python installation. I
> had
> > originally installed Python 3.6.3 for windows from python.org
> > <http://python.org>, then -- when that was unsuccessful (complained
> about
> > .startswith() args) -- rolled back to 2.7.14, also from python.org
> > <http://python.org>. This was also unsuccessful; sb-check reported
> issues with
> > host config. Uninstalled both of these, and installed mingw64/python2
> from
> > msys2, per comments in source-builder/sb/windows.py, and that allwed
> sb-check to
> > complete successfully.
> The Windows section of the user manual contains details about building on
> Windows:
> https://docs.rtems.org/branches/master/user/hosts/
> index.html#microsoft-windows
> The Python section explains the issue with Python on Windows. We are
> governed by
> GDB and what it needs.
> > Well, with one warning about SVN.
> > warning: exe: absolute exe found in path: (__svn) /usr/bin/svn
> This can be ignored.
> > I attempt to build the tools using the following command:
> > ../source-builder/sb-set-builder --log=l-arm.txt \
> > --prefix=$HOME/development/rtems/4.12 4.12/rtems-arm
> > and it fails building newlib with the following info:
> > config: tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg
> > package: arm-rtems4.12-gcc-7.2.0-newlib-2.5.0.20170922-x86_64-
> w64-mingw32-1
> > building: arm-rtems4.12-gcc-7.2.0-newlib-2.5.0.20170922-x86_64-
> w64-mingw32-1
> > error: building arg7n2xwm1
> > Build FAILED
> > See error report:
> > rsb-report-arm-rtems4.12-gcc-7.2.0-newlib-2.5.0.20170922-
> x86_64-w64-mingw32-1.txt
> > I also tried building with the additional flag --jobs=none, and receive
> the same
> > error.
> > Looking in the report, it's complaining about an include file that
> cannot be
> > located.
> > In file included from
> > ../../../../../../../../../../gcc-7.2.0/newlib/libm/machine/
> arm/s_ceil.c:39:0:
> arm/../../math/s_ceil.c:23:10:
> > fatal error: fdlibm.h: No such file or directory
> > #include "fdlibm.h"
> > compilation terminated.
> > Full report is attached.
> I have just completed an ARM build on Win10 (fully updated) without error.
> I
> noticed in the report's command line you are building under:
> C:/msys64/home/brendan/development/rtems/4.12
> This results in file names that are longer than 260 characters which is the
> default max. path length for the win32 API. Please review the comments
> here:
> index.html#windows-path-length
> I am currently using 'D:\opt\rtems\rsb.git' for the RSB repo which works.
> Chris
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20171030/8335041f/attachment.html>
