Filesystem in RTEMS
xuelin.tian at qkmtech.com
Fri Oct 20 01:50:09 UTC 2017
Thanks for your explaination : )
Best wishes,
Date: 2017-10-20 05:15
To: xuelin.tian at qkmtech.com; Sebastian Huber; users at rtems.org
Subject: Re: Filesystem in RTEMS
On 19/10/2017 19:30, xuelin.tian at qkmtech.com wrote:
> So, what is the RFS for, basically?
It is a general purpose file system for block devices. It is in use on NASA's
MMS project.
I often use it as a RAM disk file system to hold web pages and files uploaded
and downloaded via the web server. I create a RAM disk block device, format it
as RFS and then copy the web pages from a flash disk to the RAM disk.
URL: <http://lists.rtems.org/pipermail/users/attachments/20171020/6e3dd2a8/attachment-0002.html>
