Filesystem in RTEMS
xuelin.tian at qkmtech.com xuelin.tian at qkmtech.com
Mon Oct 23 09:46:51 UTC 2017
Wow, that is so cool.
I may not have enough time to do the porting :-)
Best wishes,
Date: 2017-10-23 17:26
To: xuelin.tian at qkmtech.com
CC: rtems-users at rtems.org
Subject: Re: Re: Filesystem in RTEMS
------------------ Original ------------------
From:  "xuelin.tian at qkmtech.com";<xuelin.tian at qkmtech.com>;
Date:  Mon, Oct 23, 2017 03:30 PM
To:  "jameszxj"<jameszxj at gmail.com>;"users at rtems.org"<users at rtems.org>;
> I use JFFS2 on Xilinx Zedboard, QSPI.
> The flash I use has a hybrid combination of 4KB and 64KB sectors. I just ignored the 4KB sectors, and use 64KB sectors only.
> So, the size of block is 64KB same the size of sector in my case.
> I think it may be related to my device drivers... but, I am not sure about this.
> What is your device driver in your case? Using QSPI handlers from Xilinx BSP directly?
we port QSPI Controller driver and spi nor flash driver from linux.
Best wishes,
Date: 2017-10-23 15:13
To: rtems-users at rtems.org
Subject: Re: Filesystem in RTEMS
I have encountered a problem like this.
I set wrong block size.
Maybe you can try to change the block size.
I use jffs2 on xilinx zc7020 board, QSPI
From:  "Sebastian Huber";<sebastian.huber at embedded-brains.de>;
Date:  Mon, Oct 23, 2017 01:07 PM
To:  "xuelin.tian at qkmtech.com"<xuelin.tian at qkmtech.com>;
Cc:  "users at rtems.org"<users at rtems.org>;
On 22/10/17 12:00, xuelin.tian at qkmtech.com wrote:
> I have mounted JFFS2 successfully, according to the return value.
> Yes, it takes some time to do the mounting work.
> But, when I downloaded a file like "test.txt" into flash via FTP and
> restarted the system, error came up.
Unmount the file system before you restart the system.
> <5>JFFS2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x01FC0028: 0xE5DF instead
> <5>JFFS2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x01FC002C: 0xE5DF instead
> <5>JFFS2: Further such events for this erase block will not be printed
> <5>JFFS2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x01FD0000: 0x000C instead
> <5>JFFS2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x01FD0004: 0xB0B1 instead
> <5>JFFS2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x01FD0008: 0x0054 instead
> <5>JFFS2: Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes
> <5>JFFS2: empty_blocks 0, bad_blocks 0, c->nr_blocks 510
> mount failed.
> Everything worked well, after erasing the whole flash. But errors came
> up without erasing it.
Make sure your flash driver works correctly. It must support bytewise
programming.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20171023/93e5020d/attachment-0002.html>
