Compiling Without Internet
Jacob Saina
jsaina at terpmail.umd.edu
Tue Sep 5 18:41:20 UTC 2017
Hi Chris,
I checked out "4.11" from the git repository, and did the following with
Internet:
~/workspace/rsb/rtems$ ../source-builder/sb-set-builder --dry-run
--with-download --without-error-report --without-release-url
--prefix=/home/jsaina/rtems/4.11 4.11/rtems-arm
Then I disconnected my network cable and did:
This fails as follows:
reporting: tools/rtems-gdb-7.9-1.cfg ->
arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1.xml
config: tools/rtems-tools-4.11-1.cfg
package: rtems-tools-4.11-1
git: reset: git://git.rtems.org/rtems-tools.git
git: fetch: git://git.rtems.org/rtems-tools.git ->
sources/git/rtems-tools.git
error: git command failed (/usr/bin/git): 128
Build FAILED
See error report: rsb-report-rtems-tools-4.11-1.txt
Build Set: Time 1:10:37.113829
Build FAILED
What am I misunderstanding?
Thanks for your help,
Jacob
On Fri, Sep 1, 2017 at 6:49 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 2/9/17 3:38 am, Jacob Saina wrote:
> > I'm going to be building rsb, rtems, and applications with an
> intermittent
> > Internet connection, so I'd like to have all the pieces in place on disk
> > beforehand. How can I pull down all the necessary files and avoid failing
> > because of network access?
> To fetch the packages use:
> ../source-builder/sb-set-builder \
> --dry-run --with-download \
> --without-error-report \
> --without-release-url \
> 4.12/rtems-arm
> Replace '4.12/rtems-arm' with the build set you want to build. This command
> comes from the release scripts [1].
> You should be able to move the 'source' and 'patch' contents to another
> location
> on you disk and then use the '--url' option with 'file://path'.
> Chris
> [1] https://git.rtems.org/rtems-release/tree/rtems-release-sources#n112
URL: <http://lists.rtems.org/pipermail/users/attachments/20170905/68381897/attachment-0002.html>
