Lua was Re: Quickstart Build instructions
    Russell Haley
    russ.haley at gmail.com
    Sun Apr  1 05:52:56 UTC 2018
On Fri, Mar 30, 2018 at 12:48 PM, Russell Haley <russ.haley at gmail.com>
wrote:
> On Fri, Mar 30, 2018 at 7:54 AM, Joel Sherrill <joel at rtems.org> wrote:
>> On Fri, Mar 30, 2018 at 1:05 AM, Russell Haley <russ.haley at gmail.com>
>> wrote:
>>> Thanks Joel. I haven't looped back to test if it was my mistake or
>>> something else so I'll assume my mistake for now.
>>> Either way, I'm able to build and run the examples_v2 repository against
>>> erc32, so... YAY!
>>> I'd like to build Lua 5.3, do I just build the static lib "a" file and
>>> include it in a test application? Would that happen in RTEMS proper or in
>>> waf? I need sleep now but any suggestions would be grand.
>> Porting Lua was an early GSoC project. Some information is here.:
>> https://devel.rtems.org/wiki/Packages/LUA
>> That effort predates the RSB but the proper solution would be to have
>> an RSB recipe for it. My understanding is that it was quite easy to build
>> for RTEMS.
>> https://github.com/lparam/rtems-liblua appears to be enough to help you
>> build it.
>> Needs an RSB recipe though. :)
> That would be great. I've managed to get lua 5.3 built and installed from
> the github repo by lparam. I've run out of time but will clean it up
> tonight. The SGOC link seems to be pointing to a modified/extended lua
> build and the link to the source code is dead.
> I'll try modifying the hello world example tonight as well and see what I
> get.
So building liblua.a was pretty straightforward as a "Ken" has already done
the heavy lifting in the makefile. I can call gmake as:
gmake ARCH=sparc-rtems5 BSP=erc32 BSP_BASE=~/development/rtems/5
and "make install" puts liblua.a in the correct directory. But I am getting
a linking errors with my example code that seem to imply a missing math
library? I copied the RTEMS hello example and added the Lua C example from
the Programming in Lua book (4th edition for 5.3). The files and build
output follow.
//test-lua.c
#include <bsp.h>
#include <lua.h>
#include <lualib.h>
#include <lauxlib.h>
//This is the reference to the lua interpreter
lua_State* L;
rtems_task Init(
    rtems_task_argument ignored
    lua_State *L = luaL_newstate();
    luaL_openlibs(L);
    char buff[256] = "print('Hello from Lua')";
    //Test of basic lua functionality
    int error;
    error = luaL_loadstring(L, buff);
    if(error)
        fprintf(stderr, "%s\n", lua_tostring(L,-1));
        lua_pop(L,1);
    lua_close(L);
    return 0;
/* NOTICE: the clock driver is explicitly disabled */
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MAXIMUM_TASKS 1
#define CONFIGURE_INIT
#include <rtems/confdefs.h>
/* end of file */
#wscript
# Copyright 2018 Russell Haley (russ.haley at gmail.com)
# Copyright 2013 Gedare Bloom (gedare at rtems.org)
# This file's license is 2-clause BSD as in this distribution's LICENSE.2
file.
# Waf build script for a Lua test harness
import rtems_waf.rtems as rtems
def build(bld):
    rtems.build(bld)
    bld.includes = ['.
/home/russellh/development/rtems/5/sparc-rtems5/erc32/lib/include']
    bld.read_stlib('lua',
paths=['/home/russellh/development/rtems/5/sparc-rtems5/erc32/lib/'])
    bld(features = 'c cprogram',
        target = 'test-lua.exe',
        source = ['test-lua.c'],
        use = 'lua')
#output
russellh at g1 ~/d/e/lua53-test> waf -v
Waf: Entering directory
`/usr/home/russellh/development/examples-v2/build/sparc-rtems5-erc32'
[2/3] Linking ../build/sparc-rtems5-erc32/lua53-test/test-lua.exe
22:33:27 runner ['/home/russellh/development/rtems/5/bin/sparc-rtems5-gcc',
'-qrtems', '-B/home/russellh/development/rtems/5/sparc-rtems5/lib/',
'-B/home/russellh/development/rtems/5/sparc-rtems5/erc32/lib/', '--specs',
'bsp_specs', '-mcpu=cypress', '-mcpu=cypress', '-ffunction-sections',
'-ffunction-sections', '-fdata-sections', '-fdata-sections',
'-Wl,--gc-sections', 'lua53-test/test-lua.c.2.o',
'-o/usr/home/russellh/development/examples-v2/build/sparc-rtems5-erc32/lua53-test/test-lua.exe',
'-Wl,-Bstatic',
'-L/home/russellh/development/rtems/5/sparc-rtems5/erc32/lib', '-llua',
'-Wl,-Bdynamic']
/home/russellh/development/rtems/5/sparc-rtems5/erc32/lib/liblua.a(lobject.o):
In function `numarith':
lobject.c:(.text+0x570): undefined reference to `powf'
lobject.c:(.text+0x598): undefined reference to `floorf'
lobject.c:(.text+0x5c4): undefined reference to `fmodf'
/home/russellh/development/rtems/5/sparc-rtems5/erc32/lib/liblua.a(lvm.o):
In function `luaV_tointeger':
lvm.c:(.text+0x308): undefined reference to `floorf'
In function `luaV_execute':
lvm.c:(.text+0x43cc): undefined reference to `fmodf'
lvm.c:(.text+0x4640): undefined reference to `floorf'
lvm.c:(.text+0x47f8): undefined reference to `powf'
/home/russellh/development/rtems/5/sparc-rtems5/erc32/lib/liblua.a(lmathlib.o):
In function `math_sin':
lmathlib.c:(.text+0xd8): undefined reference to `sinf'
In function `math_cos':
lmathlib.c:(.text+0x130): undefined reference to `cosf'
In function `math_tan':
lmathlib.c:(.text+0x188): undefined reference to `tanf'
In function `math_asin':
lmathlib.c:(.text+0x1e0): undefined reference to `asinf'
In function `math_acos':
lmathlib.c:(.text+0x238): undefined reference to `acosf'
In function `math_atan':
lmathlib.c:(.text+0x2b8): undefined reference to `atan2f'
In function `math_floor':
lmathlib.c:(.text+0x460): undefined reference to `floorf'
In function `math_ceil':
lmathlib.c:(.text+0x4ec): undefined reference to `ceilf'
In function `math_fmod':
lmathlib.c:(.text+0x654): undefined reference to `fmodf'
In function `math_modf':
lmathlib.c:(.text+0x720): undefined reference to `ceilf'
lmathlib.c:(.text+0x738): undefined reference to `floorf'
In function `math_sqrt':
lmathlib.c:(.text+0x7dc): undefined reference to `sqrtf'
In function `math_log':
lmathlib.c:(.text+0x8b8): undefined reference to `logf'
lmathlib.c:(.text+0x904): undefined reference to `log2f'
lmathlib.c:(.text+0x93c): undefined reference to `log10f'
lmathlib.c:(.text+0x954): undefined reference to `logf'
lmathlib.c:(.text+0x964): undefined reference to `logf'
In function `math_exp':
lmathlib.c:(.text+0x9c4): undefined reference to `expf'
In function `math_cosh':
lmathlib.c:(.text+0xf70): undefined reference to `coshf'
In function `math_sinh':
lmathlib.c:(.text+0xfc8): undefined reference to `sinhf'
In function `math_tanh':
lmathlib.c:(.text+0x1020): undefined reference to `tanhf'
In function `math_pow':
lmathlib.c:(.text+0x108c): undefined reference to `powf'
In function `math_log10':
lmathlib.c:(.text+0x11c4): undefined reference to `log10f'
collect2: error: ld returned 1 exit status
Waf: Leaving directory
Build failed
 -> task in 'test-lua.exe' failed with exit status 1:
    {task 34394256160: cprogram test-lua.c.2.o -> test-lua.exe}
['/home/russellh/development/rtems/5/bin/sparc-rtems5-gcc', '-qrtems',
'-Wl,-Bstatic',
'-Wl,-Bdynamic']
 Cheers,
Russ
> Thanks everyone!
> Russ
>> --joel
>>> Thanks!
>>> Russ
>>> On Wed, Mar 28, 2018 at 6:48 AM, Joel Sherrill <joel at rtems.org> wrote:
>>>> On Wed, Mar 28, 2018 at 12:51 AM, Russell Haley <russ.haley at gmail.com>
>>>> wrote:
>>>>> ---------- Forwarded message ----------
>>>>> From: Russell Haley <russ.haley at gmail.com>
>>>>> Date: Tue, Mar 27, 2018 at 10:45 PM
>>>>> Subject: Re: Quickstart Build instructions
>>>>> To: Sebastian Huber <sebastian.huber at embedded-brains.de>
>>>>> On Tue, Mar 27, 2018 at 10:36 PM, Sebastian Huber <
>>>>> sebastian.huber at embedded-brains.de> wrote:
>>>>>> Please send e-mails to the mailing list.
>>>>> Sorry, my mistake.
>>>>>> On 28/03/18 07:34, Russell Haley wrote:
>>>>>>> Where did the directory 5 come from in these instructions? Are you
>>>>>>> missing a mkdir?
>>>>>> The
>>>>>> --prefix=/usr/home/chris/development/rtems/5
>>>>>> directory is created by the sb-set-builder. It is the base
>>>>>> installation directory.
>>>>> I was getting a directory not writeable error until I created the
>>>>> folder myself (even after correcting for my username). I'll try again
>>>>> later, but it builds if I create the 5/ directory.
>>>> What is your $HOME? Mine is usually /home/joel. If yours is similar,
>>>> then
>>>> not being able to write into /usr as non-root is expected.
>>>> Perhaps the documentation should say ${HOME}/development/rtems/5?
>>>> FWIW Around OAR, we tend to use ${HOME}/rtems-work/tools/5 or for
>>>> wider deployments /rtems/5
>>>> --joel
>>>>> Thanks,
>>>>> Russ
>>>>>> $cd
>>>>>>> $ mkdir -p development/rtems
>>>>>>> $cd  development/rtems
>>>>>>> $ git clone git://git.rtems.org/rtems-source-builder.git <
>>>>>>> http://git.rtems.org/rtems-source-builder.git>  rsb
>>>>>>> $cd  rsb
>>>>>>> $ ./source-builder/sb-check
>>>>>>> $cd  rtems
>>>>>>> $ ../source-builder/sb-set-builder\
>>>>>>>      --prefix=/usr/home/chris/development/rtems/55/rtems-sparc
>>>>>>> Thanks,
>>>>>>> Russ
>>>>>>> On Tue, Mar 27, 2018 at 10:28 PM, Russell Haley <
>>>>>>> russ.haley at gmail.com <mailto:russ.haley at gmail.com>> wrote:
>>>>>>>     Thanks!
>>>>>>>     Russ
>>>>>>>     On Tue, Mar 27, 2018 at 10:23 PM, Sebastian Huber
>>>>>>>     <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>>>>>>         On 28/03/18 07:14, Russell Haley wrote:
>>>>>>>             Hi, the quick start indicates using ./bootstrap -p, but
>>>>>>>             using said parameter only results in the error/hep
>>>>>>> output.
>>>>>>>             Using ./bootstrap without any parameters started the the
>>>>>>>             process for me?
>>>>>>>             https://docs.rtems.org/branche
>>>>>>> s/master/user/start/index.html
>>>>>>>             <https://docs.rtems.org/branch
>>>>>>> es/master/user/start/index.html>
>>>>>>>         Sorry for the confusion. I updated the documentation:
>>>>>>>         https://git.rtems.org/rtems-docs/commit/?id=fc9db4c26eb66b1b
>>>>>>> 94f79617d850d2b0f161c00e
>>>>>>>         <https://git.rtems.org/rtems-docs/commit/?id=fc9db4c26eb66b1
>>>>>>> b94f79617d850d2b0f161c00e>
>>>>>>>         --         Sebastian Huber, embedded brains GmbH
>>>>>>>         Address : Dornierstr. 4, D-82178 Puchheim
>>>>>>> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim&entry=gmail&source=g>
>>>>>>>         <https://maps.google.com/?q=dress+:+Dornierstr.+4,+D-82178+P
>>>>>>> uchheim,&entry=gmail&source=g>
>>>>>>>         Germany
>>>>>>>         Phone   : +49 89 189 47 41-16 <tel:%2B49%2089%20189%2047%204
>>>>>>> 1-16>
>>>>>>>         Fax     : +49 89 189 47 41-09 <tel:%2B49%2089%20189%2047%204
>>>>>>> 1-09>
>>>>>>>         E-Mail  : sebastian.huber at embedded-brains.de
>>>>>>>         PGP     : Public key available on request.
>>>>>>>         Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>>>>>>>         des EHUG.
>>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>>> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim,+Germany&entry=gmail&source=g>
>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>>> _______________________________________________
>>>>> users mailing list
>>>>> users at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20180331/1f5ecb90/attachment-0001.html>
