Is there any way to tailor some rtems-libBSD functions?
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Apr 5 07:15:09 UTC 2018
Am 05.04.2018 um 04:43 schrieb Chris Johns:
>> For example, we do not need ipv6,can i exclude the function from libBSD?
> Currently there is no user accessible support. There is a task under way to
> provide user support, see https://devel.rtems.org/ticket/3351.
> There has also been discussion on the developer's list, for example
> https://lists.rtems.org/pipermail/devel/2018-April/020795.html.
> There is no time frame for this work to be completed and help even testing once
> Christian has something is always welcome.
> Chris
> users mailing list
> users at rtems.org
Hello,
if you want to reduce code size, you can actually disable some parts by
redefining some functions as empty ones. One quite big part is the WiFi
support: The WiFi support in ifconfig pulls in an xml parser libary.
That increases code size quite a bit. If you don't need that part, you
can add the following function to your application code:
    void _bsd_ifconfig_ieee80211_ctor(void)
That overwrites the one defined by libbsd and removes the WiFi support
from ifconfig. Beneath that for a really small application I also
overwrote a lot of name service functions (gethostbyname, ...) to remove
the name service in an application where it hasn't been necessary. If
you need more information on that, I can search the file with the
functions that have been relevant for this application.
Like Chris said I'm currently working on a change to the build system
that would allow to disable (beneath some other points) IPv6.
Best regards
Christian
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
