RTEMS/i.MX7D u-boot configuration.
JunBeom Kim (EmbedCoreTech) jbkim at e-coretech.kr
Thu Apr 5 10:57:09 UTC 2018
Dear Huber,
I am sorry for wrong information.
Please disregard previous question.
As I checked in many times, there is CPU0's S/W blocking case before using rtems-libbsd.
That is, there is not rtems-libbsd.
Anyway, I will try to test my SMP code using i.MX7D board next week.
Best Regards,
JunBeom Kim
-----Original Message-----
From: JunBeom Kim (EmbedCoreTech) <jbkim at e-coretech.kr>
Sent: Wednesday, April 4, 2018 1:01 PM
To: 'Sebastian Huber' <sebastian.huber at embedded-brains.de>; 'users at rtems.org' <users at rtems.org>
Subject: RE: RTEMS/i.MX7D u-boot configuration.
Dear Huber,
Thank you very much.
I was successful to booting RTEMS on i.MX6Q SDP board according to your guide.
I have very interesting problem for testing rtems-libbsd on i.MX6Q.
At this time, I am testing SMP with rtems-libbsd.
When I test SMP example without rtems-libbsd(that is, calling rtems_bsd_initialize, network_ifconfig_xxx), SMP example is working very well.
But, When I test SMP example with rtems-libbsd for calling rtems_bsd_initialize, S/W is stopped. When I check current S/W location using GDB/JTAG, Clock_isr() is still called by timer interupt. Also, _CPU_Thread_Idle_body() is running.
I guess that there is S/W blocking condition for calling rtems-libbsd API.
I don't know reason.
Anyway, I purchased i.MX7D board in today. Maybe, I can test same SMP example on both boards(i.MX7D and i.MX6Q) next week.
If I have similar problem on i.MX7D, I will let you know that.
Best Regards,
JunBeom Kim
President / EmbedCoreTech
Phone: +82-31-396-5584
Fax: +82-504-065-5720
Mobile:+82-10-6425-5720
Email: jbkim at e-coretech.kr
Web: www.e-coretech.kr
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Sent: Tuesday, April 3, 2018 5:19 PM
To: JunBeom Kim (EmbedCoreTech) <jbkim at e-coretech.kr>; users at rtems.org
Subject: Re: RTEMS/i.MX7D u-boot configuration.
On 03/04/18 10:05, JunBeom Kim (EmbedCoreTech) wrote:
> At this time, I did boot RTEMS in u-boot console according to below step in my case.
> - fatload mmc 1 0x18000000 imx6q-sabresd.dtb
> - fatload mmc 1 0x10100000 rtems.bin
> - go 0x10100000
Use bootm. You must use a Linux U-Boot image:
mkimage -A arm -O linux -T kernel -a 0x80200000 -e 0x80200000 -n RTEMS -d app.bin.gz app.img
https://www.denx.de/wiki/view/DULG/UBootCmdGroupExec#Section_5.9.4.2.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
