RTEMS booting problem for PICO-PI-IMX7 board.
Russell Haley russ.haley at gmail.com
Tue Apr 10 07:04:58 UTC 2018
I believe that any Linux distribution which supports the platform such as raspbian should have the file? This is the freebsd approach now as far as I know.
Russ
Sent from my BlackBerry 10 smartphone on the Virgin Mobile network.
  Original Message
Sent: Monday, April 9, 2018 10:50 PM
To: 'Sebastian Huber'; users at rtems.org
Subject: RE: RTEMS booting problem for PICO-PI-IMX7 board.
Dear Huber,
I think that it is another option.
But, I think that device tree based probing for ARMv7A GIC, timer, serial is best approach.
I want to use device tree based probing method continuously.
If possible, please could you send me imx7d-sdb.dtb file which you are using ?
Best Regards,
JunBeom Kim
-----Original Message-----
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Sent: Tuesday, April 10, 2018 2:28 PM
To: JunBeom Kim (EmbedCoreTech) <jbkim at e-coretech.kr>; users at rtems.org
Subject: Re: RTEMS booting problem for PICO-PI-IMX7 board.
Hello Kim,
maybe you can temporarily disable the device tree based probing and use a hard coded console device.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
