RTEMS booting problem for PICO-PI-IMX7 board.
JunBeom Kim (EmbedCoreTech) jbkim at e-coretech.kr
Tue Apr 10 15:33:40 UTC 2018
Dear Huber,
Please disregard my question about BSP_ARM_A9MPCORE_GT_BASE, BSP_ARM_A9MPCORE_SCU_BASE.
I checked this again.
Because i.MX7 port use arm-generic-timer-clock-confg.c instead of arm-a9mpcore-clock-config.c, these ZERO value will not effect any problem for i.MX7.
Best Regards,
JunBeom
-----Original Message-----
From: JunBeom Kim (EmbedCoreTech) <jbkim at e-coretech.kr>
Sent: Wednesday, April 11, 2018 12:08 AM
To: 'Sebastian Huber' <sebastian.huber at embedded-brains.de>; 'users at rtems.org' <users at rtems.org>
Subject: RE: RTEMS booting problem for PICO-PI-IMX7 board.
Dear Huber,
I think so. DTB is modified by U-Boot. I don't know the reason right now. I am checking u-boot source.
But, Because clock-frequency variable of timer is disappeared in lastest Linux kernel, you need to review arm_generic_timer_get_config() in bspstart.c
I checked "dtc command on Linux" and "fdt command on u-boot"
< dtc command on Linux >
cpu at 0 {
	compatible = "arm,cortex-a7";
	device_type = "cpu";
	reg = <0x0>;
	clock-frequency = <0x3b5dc100>;
	clock-latency = <0xee6c>;
	clocks = <0x1 0x1b5>;
	operating-points = <0xf32a0 0x106738 0xc15c0 0xee098>;
	phandle = <0x3>;
< fdt command on u-boot >
cpu at 0 {
	reg = <0x00000000>;
	clock-frequency = ";]¬;
	clock-latency = <0x0000ee6c>;
	clocks = <0x00000001 0x000001b5>;
	operating-points = <0x000f32a0 0x00106738 0x000c15c0 0x000ee098>;
	phandle = <0x00000003>;
Also, I am checking bsp/arm/imx/include/bsp.h At this time, below definition is zero.
#define BSP_ARM_A9MPCORE_GT_BASE 0
#define BSP_ARM_A9MPCORE_SCU_BASE 0
Is there any reason which this definition is zero ?
Best Regards,
JunBeom
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Sent: Tuesday, April 10, 2018 10:51 PM
To: JunBeom Kim (EmbedCoreTech) <jbkim at e-coretech.kr>; users at rtems.org
Subject: Re: RTEMS booting problem for PICO-PI-IMX7 board.
On 10/04/18 15:44, JunBeom Kim (EmbedCoreTech) wrote:
> At this time, I am checking Linux kernel's DTS building again.
The DTB is modified by U-Boot before it is handed over to the system to start. See the U-Boot sources for the details.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
