rtems shell script
bin.wang at qkmtech.com
Thu Apr 12 08:24:29 UTC 2018
hi chris:
if i use the uart as my shell output , there are print output ,but if i use the telnet as my shell output ,there are no pirnt output .
i do not know why ?
and if i add sleep cmd in the script , the cmd after the sleep can not execute, why?
thank you very much
best
ben
Date: 2018-04-12 16:12
To: Chris Johns; Users
Subject: Re: Re: rtems shell script
hi chris:
i know where i am wrong , "#! joel" there is a space in the "!" and the "joel",but at first i do not add the space.
and the file can not have suffix as ".txt", if the file has the suffix, the chmod command can not work . i do not know why.
now i can execute the script successfully ,thank you very much , but i can not see the echo in my shell output.
how can i see my command output just like i put one command in the shell ?
best
ben
Date: 2018-04-12 15:58
On 12/04/2018 17:40, Chris Johns<chrisj at rtems.org> wrote
>It can. You need to add "#! joel" as the first line and you need to set an
>appropriate the execute bit, that is user, group or other.
thank you very much
as you said i add "#! joel"as the first line ,and i change the mode to 777, but i still can not run the script,
result as follows:
[/scripts] # ./prfjog_1.txt
Unable to execute /scripts/prfjog_1.txt
[/scripts] # chmod 777 prfjog_1.txt
best
ben
Date: 2018-04-12 15:40
To: bin.wang at qkmtech.com; Users
Subject: Re: rtems shell script
On 12/04/2018 17:29, bin.wang at qkmtech.com wrote:
> hi everyone:
> this is my shell cmdline
> [/] # cd scripts
> [/scripts] # ls
> prfjog.txt
> [/scripts] # prfjog.txt
> Unable to execute /scripts/prfjog.txt
> [/scripts] # ./prfjog.txt
> i do not know whether rtems shell can execute a script?
URL: <http://lists.rtems.org/pipermail/users/attachments/20180412/eea081b7/attachment-0001.html>
