RTEMS booting problem for PICO-PI-IMX7 board.
JunBeom Kim (EmbedCoreTech) jbkim at e-coretech.kr
Mon Apr 16 06:03:38 UTC 2018
Dear Sebastian,
No problem.
I found that there is difference for accessing GT between Cortex-A7(i.MX7D) and Cortex-A9(i.MX6Q) by ARM technical manual. Therefore, arm-a9mpcore-clock-config.c should be not used for Cortex-A7 based SoC.
If I have update in my side regarding RTEMS testing on PICO-PI-IMX7, I will let you know that.
At this time, I am focusing i.MX6Q regarding SMP and USB Host, too.
On referencing, I was successful to boot SMP kernel without u-boot on i.MX6Q. but, there is still problem for booting SMP kernel with u-boot.
I guess that current problem is related with u-boot.
Best Regards,
JunBeom Kim / EmbedCoreTech
-----Original Message-----
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Sent: Monday, April 16, 2018 2:46 PM
To: JunBeom Kim (EmbedCoreTech) <jbkim at e-coretech.kr>; users at rtems.org
Subject: Re: RTEMS booting problem for PICO-PI-IMX7 board.
Hello Kim,
On 13/04/18 10:04, JunBeom Kim (EmbedCoreTech) wrote:
> Dear Sebastian,
> I returned to your original code from arm-a9mpcore-clock-config.c to arm-generic-timer-config.c.
> ( Reason ) Global timer register and SCU register can not be accessed by direct memory access. Instead of this, CP15 control access should be used.
> Is it correct ?
sorry, I don't have time currently to look at the details of this chip.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
