Timer usage
Matthew J Fletcher
amimjf at gmail.com
Wed Apr 18 14:06:04 UTC 2018
Hi,
I might give it a go,.. is
https://git.rtems.org/rtems-docs/tree/c-user/timer_manager.rst the correct
source file ?
then follow https://devel.rtems.org/wiki/Developer/Git/Users#CreatingaPatch
On 18 April 2018 at 14:40, Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Apr 18, 2018 at 8:25 AM, Matthew J Fletcher <amimjf at gmail.com>
> wrote:
>> Hi,
>> I notice that the rtems timer routines only take an inital timer fire
>> period (or an absolute time), and dont specify a re-schedule period.
>> It looks like one would use rtems_timer_reset() to re-trigger the timer
>> based on its inital fire period and rountine, but there is no mention of
>> the argument being re-passed,.. so i presume that if you wish to pass the
>> same argument again, you need to call rtems_timer_fire_after() re-passing
>> all the arguments ?
> It will have the same arguments. If you have a patch for the
> documentation, please post it.
> --joel
>> regards
>> Matthew J Fletcher
>> users mailing list
>> users at rtems.org
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20180418/04e31b46/attachment.html>
