GSOC 2018
Aditya Upadhyay aadit0402 at gmail.com
Mon Apr 30 18:16:19 UTC 2018
Hi Salil,
Thanks for introducing yourself here on RTEMS-User mailing list.
I would expect you to introduce yourself to Newlib Mailing list. Since
you have to port the code to Newlib-Cygwin
and these ported codes will be added to RTEMS Source Builder tree when
the next snapshot will be ready.
You have to make TestSuite for these ported methods to RTEMS 5*.
Regards,
Aditya Upadhyay
On Mon, Apr 30, 2018 at 11:27 PM, Salil Sirotia <salil.sirotia at gmail.com> wrote:
> Hello Users
> This is Salil Sirotia an M.Tech Scholar from IIT(ISM) Dhanbad. I came to
> know about GSOC from my seniors so i enquired more regarding and found it
> amusing after that i did my research regarding this and applied for GSOC
> 2018 and got selected.My project is POSIX Compliance  where i have to
> implement some libraries, methods and port the code to Newlib-Cygwin.
> POSIX stands for Portable Operating System Interface for uni-X. Posix
> Compliance allows us to port the source code that is running on one machine
> , can be run on another machine. This Project deals with the implementation
> of the subset of functions that are defined in POSIX 1003_1 standard, Due to
> physical resource constraints, some real-time systems like the small
> embedded system needs a limited set of operating system functionality. For
> these type of systems, it is necessary that the standard allow the
> implementation to support only a particular subset of POSIX functions. POSIX
> profiles defined in FACE Technical Standards, designed for avionics system
> verses POSIX in RTEMS where some functions are missing. These missing
> function need to be implemented. For the same I will use FreeBSD, NetBSD,
> POSIX 1003_1 as a refrence and IEEE std 1003.1 TM 2008. I will integrate
> these implemented function to Newlib. Header files and related methods that
> are not yet implemented.
> This summer I will try to do all the above task and try to gain as much as
> possible.
> Thanks & regards,
> Salil Sirotia,
> Mtech,CSE-IS(Final Year),
> IIT(ISM),Dhanbad
> users mailing list
> users at rtems.org
