Parker Solar Probe Plus Launch
Christian Mauderer list at c-mauderer.de
Sat Aug 11 15:31:04 UTC 2018
Am 07.08.2018 um 22:32 schrieb Joel Sherrill:
> Hi
> The launch window for the Parker Solar Probe
> Plus is from Aug 11 to 23 (3 days minimum).
> http://parkersolarprobe.jhuapl.edu/
> This is an RTEMS-based mission that will be
> closer to the Sun than Mercury. It will require
> 7 Venus gravity assist flybys and will make its
> first close approach in 2024.
> If someone notices the launch getting close or knows
> where to watch it online, please post.
> Thanks.
> --joel
Hello Joel,
space missions are always a great example for the widespread use of
RTEMS (in that case in terms of kilometres). So is there any reason that
would prevent this probe to be added to the list in the RTEMS wiki:
https://devel.rtems.org/wiki/TBR/UserApp/RTEMSApplications#SpaceandAviation
I can add it if you want. I just wanted to make sure that it wouldn't be
a problem before doing so.
Do you have any more (publicly available) details about where RTEMS is
used in that probe?
Best regards
Christian
