Parker Solar Probe Plus Launch
Christian Mauderer list at c-mauderer.de
Sat Aug 11 15:46:00 UTC 2018
Am 11.08.2018 um 17:35 schrieb Joel Sherrill:
> On Sat, Aug 11, 2018, 11:31 AM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     Am 07.08.2018 um 22:32 schrieb Joel Sherrill:
>     > Hi
>     > The launch window for the Parker Solar Probe
>     > Plus is from Aug 11 to 23 (3 days minimum).
>     > http://parkersolarprobe.jhuapl.edu/
>     > This is an RTEMS-based mission that will be
>     > closer to the Sun than Mercury. It will require
>     > 7 Venus gravity assist flybys and will make its
>     > first close approach in 2024.
>     > If someone notices the launch getting close or knows
>     > where to watch it online, please post.
>     > Thanks.
>     > --joel
>     Hello Joel,
>     space missions are always a great example for the widespread use of
>     RTEMS (in that case in terms of kilometres). So is there any reason that
>     would prevent this probe to be added to the list in the RTEMS wiki:
>     https://devel.rtems.org/wiki/TBR/UserApp/RTEMSApplications#SpaceandAviation
>     I can add it if you want. I just wanted to make sure that it wouldn't be
>     a problem before doing so.
> Please add it even though officially TBR is to be removed..the idea was
> to find a new way to capture the info in any TBR page when we moved to
> Trac. But there are so many still.
Missed the TBR. But as long as there is no better place ...
I hope that I didn't start a discussion about the site just now ;-)
> One is a duplication of getting started procedure between a TBR page and
> the Users Guide. Need to review to.make sure Users Guide is best
> version, change all references to old page, etc
>     Do you have any more (publicly available) details about where RTEMS is
>     used in that probe?
> On my phone but Google "flight software workshop and solar probe plus".
> That was its old name.
Thanks. Found something:
http://flightsoftware.jhuapl.edu/files/2015/Day-1/SolarProbePlusOverview.pdf
>     Best regards
>     Christian
