How to configure _Sysinit handler list?
Mon Aug 20 06:50:54 UTC 2018
On 20/08/18 08:20, Chris Johns wrote:
> On 20/08/2018 16:01, Sebastian Huber wrote:
>> On 20/08/18 05:12, Chris Johns wrote:
>>> On 17/08/2018 02:21, Aaron Bufkin wrote:
>>>> Never mind.  I figured it out.  The RTEMS_SYSINIT_ITEM() macro allows me to
>>>> insert initialization handlers to the loop that I mentioned earlier.
>>> Thank you for let us know. If you think the documentation in ...
>>> https://docs.rtems.org/branches/master/c-user/initialization.html
>>> .. could be improved we would welcome a patch.
>> The question is, if this stuff is part of the API. The RTEMS_* name suggests it,
>> however, I am not sure if we should make this a documented interface.
> I do not know, I suppose the test we should apply is what we are prepared to
> support, ie is the interface forward and backward compatibility? I, like you
> used RTEMS_* as a namespace but I do not think everything with RTEMS_* can be
> considered a formally supported interface.
> I do not know enough about the implementation here to comment on this specific item.
The system initialization is still work in progress.
The RTEMS_SYSINIT_ITEM() macro itself should be stable.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
