examples-v2 build issue with qemuprep
Matthew Gann
mgann at prc-hsv.com
Thu Aug 23 22:33:32 UTC 2018
I've modified the c/src/bsp.pc.in file and still see the same issues (still
need the -Dmpc604, and it still fails on fat_ramdisk). It looks like the
-qrtems argument did move in the argument list, but didn't fix this
particular issue. See the output below.
I've also tried disabling the build of the fat_ramdisk (and others
following it) and it still broke. Is there a better starting place than
the examples-v2 for 4.11?
[ 13/116] Compiling filesystem/fat_ramdisk/init.c
17:12:32 runner
['/opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-gcc',
'-B/opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/lib/',
'-B/opt/
development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/',
'--specs', 'bsp_specs', '-qrtems', '-mcpu=powerpc', '-mcpu=powerpc',
'-mmultiple', '-mmultiple', '-mstring',
'-mstring', '-mstrict-align', '-mstrict-align', '-O2', '-g', '-Dmpc604',
r/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/', '--specs',
'bsp_specs', '-qrtems', '-mcpu=powerpc', '-mcpu=powerpc', '-mmultiple',
'-mmultiple', '-mstring', '-mstring', '-mstrict-alig
n', '-mstrict-align', '-O2', '-g', '-Dmpc604', '-Ifilesystem/fat_ramdisk',
'-I../../filesystem/fat_ramdisk', '-DHAVE_RTEMS_SCORE_CPUOPTS_H=1',
'-DHAVE_RTEMS_H=1', '-DPACKAGE_VERSION="1.0.0"',
'../../filesystem/fat_ramdisk/init.c', '-c',
'-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/filesystem/fat_ramdisk/init.c.2.o']
powerpc-rtems4.11-gcc: fatal error:
/opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/bsp_specs:
attempt to rename spec 'endfile' to already defined spec 'old_endfile'
compilation terminated.
[ 14/116] Compiling
build/powerpc-rtems4.11-qemuprep/filesystem/fat_ramdisk/FilesystemImage.c
* Node
/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/filesystem/fat_ramdisk/FilesystemImage.c
is created more than once (full message on 'waf -v -v'). The task
generators are:
1. 'fat_ramdisk.exe' in
/opt/development/projects/booster/rtems-qemuprep/examples-v2/filesystem/fat_ramdisk
2. 'fat_ramdisk.texe' in
If you think that this is an error, set no_errcheck_out on the task instance
* Node
/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/filesystem/fat_ramdisk/FilesystemImage.h
generators are:
Waf: Leaving directory
`/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep'
Build failed
-> task in 'fat_ramdisk.exe' failed with exit status 1:
{task 139926361120232: c init.c -> init.c.2.o}
'-B/opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/',
'-mmultiple', '-mmultiple', '-mstring', '-mstring', '-mstrict-align',
On Thu, Aug 23, 2018 at 4:25 PM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Aug 23, 2018 at 4:24 PM, Joel Sherrill <joel at rtems.org> wrote:
>> On Thu, Aug 23, 2018 at 3:46 PM, Matthew Gann <mgann at prc-hsv.com> wrote:
>>> I'm focused on the 4.11 branch, as the 5 didn't seem to support the
>>> QorIQ 1020rdb board yet, which I plan on moving to when hardware is in
>>> hand. Until then, Qemuprep seemed the best emulation route...
>>> # pkg-config support file for RTEMS BSP qemuprep
>>> # Warning: This stuff is experimental and may be changed at any time.
>>> prefix=/opt/development/projects/booster/rtems-qemuprep/bsp
>>> exec_prefix=/opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11
>>> libdir=${exec_prefix}/qemuprep/lib
>>> includedir=${exec_prefix}/qemuprep/lib/include
>>> CFLAGS=-mcpu=powerpc -mmultiple -mstring -mstrict-align -D__ppc_generic
>>> -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration
>>> -Wstrict-prototypes -Wnested-externs
>>> RTEMS_BSP=qemuprep
>>> Version: 4.11.1.99
>>> Description: RTEMS BSP qemuprep
>>> Libs:
>>> Cflags: -qrtems -B${exec_prefix}/lib/ -B${libdir}/ --specs bsp_specs
>>> ${CFLAGS}
>> The Cflags is in the wrong order. Fix that by hand and file a ticket
>> against 4.11.
>> Cflags: -B${exec_prefix}/lib/ -B${libdir}/ --specs bsp_specs -qrtems
>> ${CFLAGS}
>> This .pc file is generated and it looks to be exactly the same on the
>> master
>> but it built for me on the master. So I am confused.
>> Definitely as bug though.
> The source is in c/src/bsp.pc.in. It can be fixed there.
>> --joel
>>> On Thu, Aug 23, 2018 at 3:31 PM Joel Sherrill <joel at rtems.org> wrote:
>>>> On Thu, Aug 23, 2018 at 10:34 AM, Matthew Gann <mgann at prc-hsv.com>
>>>> wrote:
>>>>> I've built the qemuprep tools and bsp, and successfully simulated the
>>>>> samples (hello.ralf, etc). I was attempting to move on to the examples-v2
>>>>> project so I could get a better feel for how to build a standalone RTEMS
>>>>> project. I have not been able to make it build correctly, and from the
>>>>> messages it seems like there may be an issue with the build. If I follow
>>>>> the directions in the README files I get the following:
>>>>> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep$ git clone -b
>>>>> 4.11 git://git.rtems.org/examples-v2.git
>>>>> Cloning into 'examples-v2'...
>>>>> remote: Counting objects: 1661, done.
>>>>> remote: Compressing objects: 100% (877/877), done.
>>>>> remote: Total 1661 (delta 1019), reused 1257 (delta 758)
>>>>> Receiving objects: 100% (1661/1661), 543.00 KiB | 211.00 KiB/s, done.
>>>>> Resolving deltas: 100% (1019/1019), done.
>>>>> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep$ cd examples-v2/
>>>>> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep/examples-v2$ git
>>>>> submodule init
>>>>> Submodule 'rtems_waf' (git://git.rtems.org/chrisj/rtems_waf.git)
>>>>> registered for path 'rtems_waf'
>>>>> submodule update
>>>>> Cloning into
>>>>> '/opt/development/projects/booster/rtems-qemuprep/examples-v2/rtems_waf'...
>>>>> Submodule path 'rtems_waf': checked out
>>>>> '7bcf72b72ec42f2feedac5f5cc5f2f57d50b5d2b'
>>>>> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep/examples-v2$ waf
>>>>> configure --rtems=${RTEMS_PATH}/bsp --rtems-tools=${RTEMS_PATH}/tools
>>>>> --rtems-bsps=powerpc/qemuprep
>>>>> Setting top to :
>>>>> Setting out to :
>>>>> Architectures : powerpc-rtems4.11
>>>>> Board Support Package : powerpc-rtems4.11-qemuprep
>>>>> Checking for program 'powerpc-rtems4.11-gcc' :
>>>>> Checking for program 'powerpc-rtems4.11-g++' :
>>>>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-g++
>>>>> Checking for program 'powerpc-rtems4.11-ld' :
>>>>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-ld
>>>>> Checking for program 'powerpc-rtems4.11-ar' :
>>>>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-ar
>>>>> Checking for program 'powerpc-rtems4.11-nm' :
>>>>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-nm
>>>>> Checking for program 'powerpc-rtems4.11-objdump' :
>>>>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-objdump
>>>>> Checking for program 'powerpc-rtems4.11-objcopy' :
>>>>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-objcopy
>>>>> Checking for program 'powerpc-rtems4.11-readelf' :
>>>>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-readelf
>>>>> Checking for program 'powerpc-rtems4.11-strip' :
>>>>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-strip
>>>>> Checking for program 'rtems-ld' :
>>>>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/rtems-ld
>>>>> Checking for program 'rtems-tld' :
>>>>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/rtems-tld
>>>>> Checking for program 'rtems-bin2c' :
>>>>> /opt/development/projects/booster/rtems-qemuprep/bsp/bin/rtems-bin2c
>>>>> Checking for program 'tar' : /bin/tar
>>>>> Checking for program 'gcc, cc' :
>>>>> Checking for program 'ar' :
>>>>> Checking if the -o link must be split from arguments : no
>>>>> Checking for program 'g++, c++' :
>>>>> Checking for program 'gas, gcc' :
>>>>> Checking for RTEMS headers : started
>>>>> -> processing test results : all ok
>>>>> Checking for RTEMS_DEBUG : no
>>>>> Checking for RTEMS_MULTIPROCESSING : no
>>>>> Checking for RTEMS_NEWLIB : yes
>>>>> Checking for RTEMS_POSIX_API : yes
>>>>> Checking for RTEMS_SMP : no
>>>>> Checking for RTEMS_NETWORKING : yes
>>>>> Checking for RTEMS_ATOMIC : no
>>>>> 'configure' finished successfully (3.420s)
>>>>> -v
>>>>> Waf: Entering directory
>>>>> [ 1/116] Creating
>>>>> 10:24:16 runner ' tar -C
>>>>> /opt/development/projects/booster/rtems-qemuprep/examples-v2/filesystem/fat_ramdisk/rootfs
>>>>> -cf filesystem/fat_ramdisk/FilesystemImage . '
>>>>> [ 2/116] Creating
>>>>> build/powerpc-rtems4.11-qemuprep/file_io/crc/FilesystemImage
>>>>> /opt/development/projects/booster/rtems-qemuprep/examples-v2/file_io/crc/rootfs
>>>>> -cf file_io/crc/FilesystemImage . '
>>>>> [ 3/116] Processing
>>>>> 10:24:16 runner '
>>>>> && touch
>>>>> [ 4/116] Processing
>>>>> 10:24:16 runner '
>>>>> && touch
>>>>> [ 5/116] Processing
>>>>> 10:24:16 runner '
>>>>> /opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/file_io/crc/FilesystemImage.c
>>>>> && touch
>>>>> /opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/file_io/crc/FilesystemImage.h
>>>>> [ 6/116] Compiling
>>>>> 10:24:16 runner
>>>>> '-qrtems',
>>>>> '--specs', 'bsp_specs', '-mcpu=powerpc', '-mcpu=powerpc', '-mmultiple',
>>>>> '-mmultiple', '-mstring', '-mstring', '-mstrict-align', '-mstrict-align',
>>>>> '-O2', '-g', '-qrtems',
>>>>> '-O2', '-g', '-Ifile_io/crc', '-I../../file_io/crc',
>>>>> '-DHAVE_RTEMS_SCORE_CPUOPTS_H=1', '-DHAVE_RTEMS_H=1',
>>>>> '-DPACKAGE_VERSION="1.0.0"', 'file_io/crc/FilesystemImage.c', '-c',
>>>>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/file_io/crc/FilesystemImage.c.2.o']
>>>>> [ 7/116] Compiling hello/hello_world_c/test.c
>>>>> 10:24:16 runner
>>>>> '-qrtems',
>>>>> '-O2', '-g', '-DHAVE_RTEMS_SCORE_CPUOPTS_H=1', '-DHAVE_RTEMS_H=1',
>>>>> '../../hello/hello_world_c/test.c', '-c',
>>>>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/hello/hello_world_c/test.c.1.o']
>>>>> [ 8/116] Compiling hello/posix_hello_world/test.c
>>>>> 10:24:16 runner
>>>>> '-qrtems',
>>>>> '../../hello/posix_hello_world/test.c', '-c',
>>>>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/hello/posix_hello_world/test.c.1.o']
>>>>> [ 9/116] Compiling hello/both_hello/test.c
>>>> I tried this on the master and qemuprep built the examples OK.
>>>> I am unsure how well the waf for examples-v2 worked on 4.11 but for
>>>> some reason the -qrtems flag is in the wrong place and -B is twice. It
>>>> should be:
>>>> -B PREFIX/TARGET/BSP/lib/ -specs bsp_specs -qrtems
>>>> and those arguments should be in that exact order and no part of them
>>>> should appear twice.
>>>> In this case, the -qrtems is too early and having no impact which I
>>>> think explains the issues.
>>>> What's the installed file powerpc-rtems5-qemuprep.pc contain?
>>>>> In file included from
>>>>> /opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/include/libcpu/powerpc-utility.h:40:0,
>>>>> from
>>>>> /opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/include/bsp/vectors.h:40,
>>>>> from
>>>>> /opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/include/bsp.h:17,
>>>>> from ../../hello/posix_hello_world/test.c:20:
>>>>> /opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/include/rtems/powerpc/powerpc.h:283:2:
>>>>> error: #error "Unsupported CPU Model"
>>>>> from
>>>>> from
>>>>> from ../../hello/hello_world_c/test.c:21:
>>>>> * Node
>>>>> generators are:
>>>>> instance
>>>>> * Node
>>>>> generators are:
>>>>> instance
>>>>> Build failed
>>>>> -> task in 'crc.exe' failed with exit status 1:
>>>>> {task 140287200672176: c FilesystemImage.c -> FilesystemImage.c.2.o}
>>>>> '-qrtems',
>>>>> -> task in 'posix_hello.exe' failed with exit status 1:
>>>>> {task 140287209486528: c test.c -> test.c.1.o}
>>>>> '-qrtems',
>>>>> -> task in 'hello.exe' failed with exit status 1:
>>>>> {task 140287209485568: c test.c -> test.c.1.o}
>>>>> '-qrtems',
>>>>> If I change the following line in the wscript to add -Dmpc604 "bld.env.CFLAGS
>>>>> += ['-O2','-g','-Dmpc604']" I get this error:
>>>>> clean
>>>>> 'clean-powerpc-rtems4.11-qemuprep' finished successfully (0.017s)
>>>>> Setting top to :
>>>>> Setting out to :
>>>>> 'configure' finished successfully (0.614s)
>>>>> -v
>>>>> [ 1/116] Creating
>>>>> 10:30:49 runner ' tar -C
>>>>> [ 2/116] Creating
>>>>> [ 3/116] Processing
>>>>> 10:30:49 runner '
>>>>> && touch
>>>>> [ 4/116] Processing
>>>>> 10:30:49 runner '
>>>>> && touch
>>>>> [ 5/116] Processing
>>>>> 10:30:49 runner '
>>>>> && touch
>>>>> [ 6/116] Compiling hello/hello_world_c/test.c
>>>>> 10:30:49 runner
>>>>> '-qrtems',
>>>>> '-O2', '-g', '-Dmpc604', '-DHAVE_RTEMS_SCORE_CPUOPTS_H=1',
>>>>> '-DHAVE_RTEMS_H=1', '../../hello/hello_world_c/test.c', '-c',
>>>>> [ 7/116] Compiling hello/posix_hello_world/test.c
>>>>> 10:30:49 runner
>>>>> '-qrtems',
>>>>> '-DHAVE_RTEMS_H=1', '../../hello/posix_hello_world/test.c', '-c',
>>>>> [ 8/116] Compiling hello/both_hello/test.c
>>>>> 10:30:49 runner
>>>>> '-qrtems',
>>>>> '-DHAVE_RTEMS_H=1', '../../hello/both_hello/test.c', '-c',
>>>>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/hello/both_hello/test.c.1.o']
>>>>> 10:30:49 runner
>>>>> '-qrtems',
>>>>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/hello/both_hello/test.c.2.o']
>>>>> [ 10/116] Compiling hello/both_hello/test.c
>>>>> 10:30:49 runner
>>>>> '-qrtems',
>>>>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/hello/both_hello/test.c.3.o']
>>>>> [ 11/116] Compiling gdb/overwrite/overwrite.c
>>>>> 10:30:49 runner
>>>>> '-qrtems',
>>>>> '-DHAVE_RTEMS_H=1', '../../gdb/overwrite/overwrite.c', '-c',
>>>>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/gdb/overwrite/overwrite.c.1.o']
>>>>> [ 12/116] Compiling gdb/overwrite/rtems_init.c
>>>>> 10:30:49 runner
>>>>> '-qrtems',
>>>>> '-DHAVE_RTEMS_H=1', '../../gdb/overwrite/rtems_init.c', '-c',
>>>>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/gdb/overwrite/rtems_init.c.1.o']
>>>>> 10:30:49 runner
>>>>> '-qrtems',
>>>>> '-O2', '-g', '-Dmpc604', '-qrtems',
>>>>> * Node
>>>>> generators are:
>>>>> instance
>>>>> * Node
>>>>> generators are:
>>>>> instance
>>>>> Build failed
>>>>> {task 140363104493032: c init.c -> init.c.2.o}
>>>>> '-qrtems',
>>>>> Is there something I'm doing wrong, or is there a simple fix for
>>>>> this?
>>>>> Thanks in advance
>>>>> Matthew Gann
>>>>> Senior Engineer - Paragon Research Corporation
>>>>> This message is intended for the addressee only and may contain
>>>>> Paragon Research Corporation (PRC) confidential or privileged information.
>>>>> Use or distribution of such confidential information is strictly prohibited
>>>>> without the prior written permission of PRC. If you have received this
>>>>> message in error, please contact the sender immediately and delete the
>>>>> message and attachments from your computer.
>>>>> _______________________________________________
>>>>> users mailing list
>>>>> users at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/users
>>> Matthew Gann
>>> This message is intended for the addressee only and may contain Paragon
>>> Research Corporation (PRC) confidential or privileged information. Use or
Matthew Gann
URL: <http://lists.rtems.org/pipermail/users/attachments/20180823/b799b557/attachment-0001.html>
