rtems-libbsd fails for gr740
Nicolas Tsiogkas
lou.nick at gmail.com
Fri Aug 24 08:59:49 UTC 2018
Hi,
I am trying to build the libbsd for a gr740 target. It fails while building
debugger01.exe with error:
Waf: Entering directory
`/home/niko/rtems/rtems-src/rtems-libbsd/build/sparc-rtems5-gr740-default'
[1906/2014] Linking build/sparc-rtems5-gr740-default/debugger01.exe
/home/niko/rtems/5/lib/gcc/sparc-rtems5/7.3.0/../../../../sparc-rtems5/bin/ld:
cannot find -ldebugger
collect2: error: ld returned 1 exit status
Waf: Leaving directory
Build failed
-> task in 'debugger01.exe' failed with exit status 1 (run with -v to
display more information)
as far as I understand debugger was moved out of libbsd but it is not built
for the gr740 for some reason. Is this a known normal behaviour?
In addition which networking stack version is used in the rtems kernel
(when I build with --enable-networking)? Is it from FreeBSD9.3 or even
older? as the bpf provided there is not on par with the rtems-libbsd one.
Thanks in advance for your time.
Kind regards,
Niko
URL: <http://lists.rtems.org/pipermail/users/attachments/20180824/cbac4759/attachment.html>
