rtems-libbsd fails for gr740
Fri Aug 24 09:23:42 UTC 2018
Hello Nicolas,
On 24/08/18 10:59, Nicolas Tsiogkas wrote:
> Hi,
> I am trying to build the libbsd for a gr740 target. It fails while
> building debugger01.exe with error:
> Waf: Entering directory
> `/home/niko/rtems/rtems-src/rtems-libbsd/build/sparc-rtems5-gr740-default'
> [1906/2014] Linking build/sparc-rtems5-gr740-default/debugger01.exe
> /home/niko/rtems/5/lib/gcc/sparc-rtems5/7.3.0/../../../../sparc-rtems5/bin/ld:
> cannot find -ldebugger
> collect2: error: ld returned 1 exit status
> Waf: Leaving directory
> Build failed
>  -> task in 'debugger01.exe' failed with exit status 1 (run with -v to
> display more information)
> as far as I understand debugger was moved out of libbsd but it is not
> built for the gr740 for some reason. Is this a known normal behaviour?
do you have this error with the latest master versions of RTEMS and libbsd?
> In addition which networking stack version is used in the rtems kernel
> (when I build with --enable-networking)? Is it from FreeBSD9.3 or even
> older? as the bpf provided there is not on par with the rtems-libbsd one.
The network stack included in the RTEMS sources is about 20 years old.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
