rtems-libbsd fails for gr740
Mon Aug 27 06:35:12 UTC 2018
Hello Nicolas,
I tried it on a VM with the steps below and can reproduce your problem.
The waf configure checks a header file:
Configure variant:                          : sparc-rtems5-gr740-default
Checking for header rtems/rtems-debugger.h  : yes
'configure' finished successfully (0.953s)
This is later used in:
         self.addTest(mm.generator['test-if-header']('debugger01',
'rtems/rtems-debugger.h',
                                                     ['test_main'],
runTest = False, netTest = True,
                                                     extraLibs =
['debugger']))
I have no idea why this works on my main development machine. We should
check that the libdebugger.a is present and not the header file. For
now, please remove the lines above from libbsd.py.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
