rtems-libbsd fails for gr740
Nicolas Tsiogkas
lou.nick at gmail.com
Mon Aug 27 10:21:12 UTC 2018
Yup that did the trick. Thanks!
Regards,
Niko
On Mon, Aug 27, 2018 at 8:35 AM Sebastian Huber <
> Hello Nicolas,
> I tried it on a VM with the steps below and can reproduce your problem.
> The waf configure checks a header file:
> Configure variant: : sparc-rtems5-gr740-default
> Checking for header rtems/rtems-debugger.h : yes
> 'configure' finished successfully (0.953s)
> This is later used in:
> self.addTest(mm.generator['test-if-header']('debugger01',
> 'rtems/rtems-debugger.h',
> ['test_main'],
> runTest = False, netTest = True,
> extraLibs =
> ['debugger']))
> I have no idea why this works on my main development machine. We should
> check that the libdebugger.a is present and not the header file. For
> now, please remove the lines above from libbsd.py.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20180827/636e1953/attachment.html>
