Parker Solar Probe Plus Launch
    Joel Sherrill
    joel at rtems.org
    Sat Aug 11 15:35:04 UTC 2018
On Sat, Aug 11, 2018, 11:31 AM Christian Mauderer <list at c-mauderer.de>
wrote:
> Am 07.08.2018 um 22:32 schrieb Joel Sherrill:
> > Hi
> > The launch window for the Parker Solar Probe
> > Plus is from Aug 11 to 23 (3 days minimum).
> > http://parkersolarprobe.jhuapl.edu/
> > This is an RTEMS-based mission that will be
> > closer to the Sun than Mercury. It will require
> > 7 Venus gravity assist flybys and will make its
> > first close approach in 2024.
> > If someone notices the launch getting close or knows
> > where to watch it online, please post.
> > Thanks.
> > --joel
> Hello Joel,
> space missions are always a great example for the widespread use of
> RTEMS (in that case in terms of kilometres). So is there any reason that
> would prevent this probe to be added to the list in the RTEMS wiki:
> https://devel.rtems.org/wiki/TBR/UserApp/RTEMSApplications#SpaceandAviation
> I can add it if you want. I just wanted to make sure that it wouldn't be
> a problem before doing so.
Please add it even though officially TBR is to be removed..the idea was to
find a new way to capture the info in any TBR page when we moved to Trac.
But there are so many still.
One is a duplication of getting started procedure between a TBR page and
the Users Guide. Need to review to.make sure Users Guide is best version,
change all references to old page, etc
> Do you have any more (publicly available) details about where RTEMS is
> used in that probe?
On my phone but Google "flight software workshop and solar probe plus".
That was its old name.
> Best regards
> Christian
URL: <http://lists.rtems.org/pipermail/users/attachments/20180811/85e7e8b2/attachment-0002.html>
