Cache routines working with a processor set?
Fri Dec 21 14:06:19 UTC 2018
Hello Daniel,
On 21/12/2018 14:55, Daniel Hellstrom wrote:
> I missed to respond to this email.. It is not currently used by our
> drivers currently, I think the original use case here is when
> L3/L2/L1-cache is not updated after DMA. For example, the GR740 can be
> configured to make DMA directly to SDRAM memory, "behind" the
> L2-cache. In this mode the system is not coherent. To avoid the L2
> cache containing incorrect data, one approach is to use a "DMA address
> region" and configure a L2-cache MTR regions. However, the L1-cache
> would still not be updated since it L1 D-cache is not snooping the
> memory bus but only the CPU bus which the DMA master is not writing to
> in this configuration. Using the MMU and marking pages non-cacheable
> could resolve this to a cost. Another approach would be to flush those
> lines or the whole D-cache instead of using the MMU. At that time, it
> was under consideration to add line/page flushing to the GR740 L1-cache.
this sounds like a very specialized use case. I don't think we should
provide an architecture-independent API for this. If you really need
this for a highly optimized driver on the GR740, you can use a special
purpose function.
> For the I-cache we need to flush when modifying instructions, like the
> trap vector. But this patch seems to only involve d-cache.
The instruction cache software broadcast is still supported.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
