RTEMS POSIX Priority Inversion Issue.
JunBeom Kim (EmbedCoreTech)
jbkim at e-coretech.kr
Fri Dec 28 06:45:34 UTC 2018
Dear Sir,
I am testing RTEMS POSIX thread priority.
I am still using RTEMS 4.12 in 2017 year.
There are four pthreads(main, pthread1, pthread2, pthread3) on two cores in
my test case.
- main pthread is running on core 1.
- pthread1, pthread2, pthread3 is running on core 2.
- All threads are doing GPIO toggling action in while(1) loop.
- my configuration for timeslice quantum is 25ms.
As I know from RTEMS POSIX manual, there is below statement.
In the RTEMS implementation of the POSIX API, the priorities range from the
low priority of
sched_get_priority_min() to the highest priority of
sched_get_priority_max(). Numerically
higher values represent higher priorities.
But, when I test this, lower value is doing as higher priority. Higher value
is doing as lower priority.
Is this correct operation ?
Case 0) All threads are same priority.
[/] # pthread
ID NAME CPU SHED PRI STATE MODES EVENTS WAITINFO
0b010001 main_thread 1 MEDF 2147483645 READY P:T:nA NONE
0b010002 pthread1 2 MEDF 2147483645 READY P:T:nA NONE
0b010003 pthread2 2 MEDF 2147483645 READY P:T:nA NONE
0b010004 pthread3 2 MEDF 2147483645 READY P:T:nA NONE
Case 1) pthread3 is lower priority according to manual. But, pthread3 is
higher priority in my case.
[/] # pthread
0b010002 pthread1 2 MEDF 2147483646 READY P:T:nA NONE
0b010003 pthread2 2 MEDF 2147483646 READY P:T:nA NONE
0b010004 pthread3 2 MEDF 1789569706 READY P:T:nA NONE
Case 2) pthread3 is higher priority according to manual. pthread1 and
pthread2 are higher priority than pthread3.
[/] # pthread
0b010002 pthread1 2 MEDF 1789569706 READY P:T:nA NONE
0b010003 pthread2 2 MEDF 1789569706 READY P:T:nA NONE
0b010004 pthread3 2 MEDF 2147483646 READY P:T:nA NONE
Please advise.
Best Regards,
JunBeom Kim
President / EmbedCoreTech
Phone: +82-31-396-5584
Fax: +82-504-065-5720
Mobile:+82-10-6425-5720
Email: <mailto:jbkim at e-coretech.kr> jbkim at e-coretech.kr
Web: <http://www.e-coretech.kr> www.e-coretech.kr
URL: <http://lists.rtems.org/pipermail/users/attachments/20181228/812bf075/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20181228/812bf075/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20181228/812bf075/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20181228/812bf075/attachment-0005.png>
