Problems with RTEMS toolchain build 4.12 & 5 incl. Ada support
    Chris Johns
    chrisj at rtems.org
    Sun Dec  2 22:36:35 UTC 2018
On 30/11/2018 19:01, Sebastian Huber wrote:
> I regularly build the RTEMS 5 tools with Ada support using the RSB, e.g.
> cd $RSB/rtems
> ../source-builder/sb-set-builder --prefix=/opt/rtems/5 5/rtems-sparc --with-ada
Great. Have you posted any of these builds to build at rtems.org?
> The host and target GCC versions must match to build Ada. So, building the 6.3.0
> RTEMS target GCC with a 7.1.0 host GCC will not work.
Should the RSB check the version of GCC's Gnat?
> You must not have a previous installation in the prefix if you build new tools
> with Ada support.
Oh this complicated issue again [1]. I suspect this one is not going to go away
in a hurry and the solution will need to be clearly thought out.
Could you please update the ticket with this detail so it is captured? I have
not built Ada for RTEMS so I am not sure what the exe prefixes etc are.
> The documentation
> https://docs.rtems.org/branches/master/rsb/building-tools-and-rtems.html#controlling-the-build
> should probably be updated to mention this.
I see a patch from you, thank you. I will review it today.
> I would use the latest RTEMS.
Sure and thanks.
[1] https://devel.rtems.org/ticket/2540
