Problems with RTEMS toolchain build 4.12 & 5 incl. Ada support
chris at kluge-rocks.de
Mon Dec 3 18:39:29 UTC 2018
Hi,
FYI, I've added the scripts and stuff I used for the build to github.
scripts used for the toolchain build:
https://github.com/CTrocks/rtems-build-scripts
Dockerfile for the build (uses the above scripts):
https://github.com/CTrocks/rtems-build-toolchain-docker
I'll drop a message here once I can provide something which might be of interest.
Thanks again!
December 3, 2018 1:18 AM, "Sebastian Huber" <sebastian.huber at embedded-brains.de> wrote:
> On 02/12/2018 23:36, Chris Johns wrote:
>> On 30/11/2018 19:01, Sebastian Huber wrote:
>>> I regularly build the RTEMS 5 tools with Ada support using the RSB, e.g.
>>> cd $RSB/rtems
>>> ../source-builder/sb-set-builder --prefix=/opt/rtems/5 5/rtems-sparc --with-ada
>> Great. Have you posted any of these builds to build at rtems.org?
> Yes, I always build and report --with-ada on arm, powerpc, and sparc.
> You see this in the report at a glance in the extra
> languages="$languages,ada"
> line.
>>> The host and target GCC versions must match to build Ada. So, building the 6.3.0
>>> RTEMS target GCC with a 7.1.0 host GCC will not work.
>> Should the RSB check the version of GCC's Gnat?
> I guess neither you nor I have the time to add this. Ada support has a
> very low priority for me.
>>> You must not have a previous installation in the prefix if you build new tools
>>> with Ada support.
>> Oh this complicated issue again [1]. I suspect this one is not going to go away
>> in a hurry and the solution will need to be clearly thought out.
>> Could you please update the ticket with this detail so it is captured? I have
>> not built Ada for RTEMS so I am not sure what the exe prefixes etc are.
> I think
> https://devel.rtems.org/ticket/2540#comment:16
> covers all major problems with an existing installation.
>>> The documentation
>>> https://docs.rtems.org/branches/master/rsb/building-tools-and-rtems.html#controlling-the-build
>>> should probably be updated to mention this.
>> I see a patch from you, thank you. I will review it today.
>>> I would use the latest RTEMS.
>> Sure and thanks.
> Building the tools with Ada support in RTEMS 4.11 and before is a lot
> more complicated. I also fixed a couple of Ada related issues during the
> RTEMS 5 development cycle. I run the Ada tests by default since a couple
> of months.
>> Chris
>> [1] https://devel.rtems.org/ticket/2540
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
