Building rtems 4.11.3
    Chris Johns
    chrisj at rtems.org
    Wed Dec 12 23:17:00 UTC 2018
On 13/12/18 3:16 am, Ricardo Derbes wrote:
> Hello.
> I'm currently using rtems-4.10.2 but trying to upgrade to rtems-4.11.3
> Due to network restrictions, I can not to use RSB,
Could you please try downloading the `sources` directory from ...
 https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.3/sources/
plus the RSB ...
 https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.3/rtems-source-builder-4.11.3.tar.xz
and then use the --url=file://path-to-the-sources with the RSB? I have not
tested this on 4.113 or for a while but the option is there for this reason.
If this does not work have a look in the RSB sources for VERSION at the top, it
has the path to the release sources. See if you can set a local path you can access.
> so I'm trying to build it the
> classic way: bootstrap, configure, make, make install, but I cannot find the
> right toolchain, if I try to use the same of 4.10.2 I get a fatal error starting at:
> In file included from
> ../../../../cpukit/../../../leon3/lib/include/rtems/score/percpu.h:29,
>                  from
> ../../../../../../../../rtems-4.11.3/c/src/../../cpukit/score/cpu/sparc/cpu.c:22:
> ../../../../cpukit/../../../leon3/lib/include/rtems/score/timestamp.h: In
> function '_Timestamp_Set':
> ../../../../cpukit/../../../leon3/lib/include/rtems/score/timestamp.h:78:
> warning: implicit declaration of function 'timespec2bintime'
> warning: nested extern declaration of 'timespec2bintime'
> and so on.
> Which is the right toolchain version for this release? Where can I download it from?
You need the tools that match the 4.11.3 release.
