__undef_stack and _stack_end from __GNUC__ not supported in RTEMS
Fernando Domínguez
fdpousa at gmail.com
Thu Feb 1 14:28:34 UTC 2018
Hi,
I'm trying to move a SD card driver for Xilinx Zynq (Zedboard) to RTEMS.
During linking phase, the following errors arise:
/home/fdpo/xilinx_hal/xilinx_aux/src/xil_cache.c:790: undefined reference
to `__undef_stack'
to `_stack_end'
to `_stack_end'
to `__undef_stack'
On file xil_cache.c, this declaration is inside a __GNUC__ guard:
#ifdef __GNUC__
extern s32 _stack_end;
extern s32 __undef_stack;
#endif
And then used in some functions only in this way:
#ifdef __GNUC__
stack_end = (u32)&_stack_end;
stack_start = (u32)&__undef_stack;
stack_size=stack_start-stack_end;
/*Flush stack memory to save return address*/
Xil_DCacheFlushRange(stack_end, stack_size);
#endif
How can I assign a stack_end, a stack_start and stack_size from RTEMS? I
suppse stack_size is the same one as configured a initialization but others
I attach you the xil_cache.h/c files.
Thanks in advance,
Fernand
URL: <http://lists.rtems.org/pipermail/users/attachments/20180201/44b61f8e/attachment-0001.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20180201/44b61f8e/attachment-0002.bin>
Type: text/x-chdr
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20180201/44b61f8e/attachment-0003.bin>
