RES: Problems with RTEMS installation - coming from 4.10
Fabrício de Novaes Kucinskis
fabricio.kucinskis at inpe.br
Mon Feb 5 10:45:33 UTC 2018
Hi Mr. Silva, long time no see!
Sorry for the delay on answering, just this weekend I could resume this task (don't let my wife know!!).
Thanks for the link. As I suspected, I was missing something very very basic: I didn't build the BSP. Let me explain why, maybe it can help improving the documentation a little.
I was misled by the item 7.2.1 of the on-line user manual which, at the end of the page, states that "you can now build a 3rd party library or an application". This, and the fact that the next page of the manual deals with a different way to build RTEMS (from git), made me assume the installation was finished and that the RSB included the configure script to build all BSP's of the selected architecture.
It's clearly my fault, but it would help if the item 7.2.1 continued with bootstrap and the configure script before changing the topic.
Now everything is ok and I can start updating my old 4.10 project to 4.11.2. Let's see what's new on RTEMS!
Thanks again and best regards,
Fabrício.
De: Wendell Silva [mailto:silvawp at gmail.com]
Enviada em: quarta-feira, 31 de janeiro de 2018 15:19
Para: Fabrício de Novaes Kucinskis <fabricio.kucinskis at inpe.br>
Cc: RTEMS Users <rtems-users at rtems.org>
Assunto: Re: Problems with RTEMS installation - coming from 4.10
On your question #2, I've successfully executed the procedure documented here <https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start> .
Best Regards,
--Wendell
On Wed, Jan 31, 2018 at 3:00 PM Wendell Silva <silvawp at gmail.com <mailto:silvawp at gmail.com> > wrote:
Hi Mr. Kucinskis,
Please, try this:
gcc -mcpu=cypress -ffunction-sections -fdata-sections -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -I${prefix}/sparc-rtems4.11/sis/lib/include -B${prefix}/sparc-rtems4.11/sis/lib -specs bsp_specs -qrtems -lrtemsbsp -lrtemscpu test.c -o test.exe
You can also use Makefile.{leaf|dir|lib} at RTEMS source code/make/Templates as "inspiration".
Hope it helps you.
--Wendell.
On Wed, Jan 31, 2018 at 2:41 PM Fabrício de Novaes Kucinskis <fabricio.kucinskis at inpe.br <mailto:fabricio.kucinskis at inpe.br> > wrote:
Hello everyone, it's been a while since my last message to the list.
I'm setting up a new development environment to start updating a project from RTEMS 4.10 to 4.11.2. It's based on Fedora 27.
The installation process through source-builder is very different from the one I was used to (based on tools in RPM and the 'configure' script), but it's pretty easy. Congrats for the improvement!
I followed the instructions on https://docs.rtems.org/branches/master/user/installation/releases.html, just changing the prefix ('/comav/rtems/build' instead of '/opt/rtems/4.11').
After installing the usual missing dependencies found during the build, it finished with success and everything seemed to be ok. Then I've downloaded the 'examples' package and tried to compile hello_world_c with the simplest command possible:
sparc-rtems4.11-gcc test.c -o test.exe
Just to get the following error:
"test.c:5:19: fatal error: rtems.h: No such file or directory"
Then I realized I had not set $RTEMS_MAKEFILE_PATH. I did it, pointing to "{prefix}/sparc-rtems4.11/sis", with no effect. So I noticed there's no reference to such environment variable on the current documentation. Question nr. 1: is it still needed?
Afterwards, I tried to compile, this time manually stating the include path with "-I{prefix}/lib/include". This way the compiler finds rtems.h, but I get a lot of errors, starting with ld complaining it haven't found "_start" and other basic BSP symbols.
Probably I'm missing something basic, but for now I can't find out. Question nr. 2: Am I doing something wrong, or missing some installation step?
Thanks in advance and best regards,
Fabrício Kucinskis.
users mailing list
users at rtems.org <mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users
--Wendell
--Wendell
URL: <http://lists.rtems.org/pipermail/users/attachments/20180205/9a6428af/attachment.html>
