__undef_stack and _stack_end from __GNUC__ not supported in RTEMS
Wed Feb 7 03:31:11 UTC 2018
On 02/02/2018 01:28, Fernando Domínguez wrote:
> Hi,
> I'm trying to move a SD card driver for Xilinx Zynq (Zedboard) to RTEMS. During
> linking phase, the following errors arise:
> /home/fdpo/xilinx_hal/xilinx_aux/src/xil_cache.c:790: undefined reference to
> `__undef_stack'
> `_stack_end'
> `_stack_end'
> `__undef_stack'
> On file xil_cache.c, this declaration is inside a __GNUC__ guard:
> #ifdef __GNUC__
>     extern s32  _stack_end;
>     extern s32  __undef_stack;
> #endif
> And then used in some functions only in this way:
> #ifdef __GNUC__
>     stack_end = (u32)&_stack_end;
>     stack_start = (u32)&__undef_stack;
>     stack_size=stack_start-stack_end;
>     /*Flush stack memory to save return address*/
>     Xil_DCacheFlushRange(stack_end, stack_size);
> #endif
> How can I assign a stack_end, a stack_start and stack_size from RTEMS? I suppse
> stack_size is the same one as configured a initialization but others
I suggest you avoid using the Xilinx cache code and create a wrapper for the
Xilinx cache routines to the RTEMS cache routines.
