GSoC'18-Introduction
Udit agarwal dev.madaari at gmail.com
Mon Feb 26 07:08:00 UTC 2018
Hi,
So, the error turned out to be due to missing dts only, after building the
scripts again with FDT, both the I2C sample code(Logs:here
<https://gist.github.com/madaari/1cd3ff8a81327726f56b9cef502c529e>),
media01(Logs:here
<https://gist.github.com/madaari/0336c3d44228e9f171510819b2d235d7>) example
worked flawlessly, and thus i was able to read sd-card data. What could be
my next possible task on libbsd?
Moreover, I tried building wifi sample app as well, but i have Atheros
AR9271(Firmware name:  ath9k_htc/htc_9271-1.4.0.fw) wireless card.
Following sichen's blog posts(here
<https://sichenzhao.blogspot.in/2017/06/rtems-libbsd-generates-drive-device.html>)
i tried building support for my wireless card, but it looks like FreeBSD
itself lacks support for this( as mentioned here )
<https://wiki.freebsd.org/dev/ath%284%29>
Is there any other way, apart from using FreeBSD for generating support for
my wifi card?
Moreover, regarding libbsd documentation, i am keeping note of every step,
and will soon update the document(libbsd.txt).
Thanks,
Udit Agarwal
On Sun, Feb 25, 2018 at 11:15 PM, Russell Haley <russ.haley at gmail.com>
wrote:
> Sorry for the top post.
> Dts file in freebsd tree are here. The Dts files are imported from Linux
> for compatability.
> https://svnweb.freebsd.org/base/head/sys/gnu/dts/arm/
> Russ
> Sent from my BlackBerry 10 smartphone on the Virgin Mobile network.
>   Original Message
> From: Christian Mauderer
> Sent: Sunday, February 25, 2018 2:32 AM
> To: Udit agarwal; Users
> Subject: Re: GSoC'18-Introduction
> Am 25.02.2018 um 08:41 schrieb Udit agarwal:
> > Hi,
> > I did build libbsd for beagleboneBlack and executed selectpollkqueue01
> > test successfully.(Logs:here
> > <https://gist.github.com/madaari/ae7b3334514a9aec3b063eaa3a0dcd05>)
> > However, while trying to access SD card, media01 test failed with an
> > error "fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)  " (Logs:here
> > <https://gist.github.com/madaari/c6d524bc06e896359f9535d90c0a447a>)
> > I tried debugging the script, by putting printf statements in various
> > functions, but it seems like it's failing even before entering
> test_main().
> > Also, is there a better method with which we can debug RTEMS scripts?
> > Thanks,
> > Udit Agarwal
> Hello Udit,
> it's great that you can already compile and run some of the libbsd
> examples.
> Regarding your problem with the SD card: Note that the BBB BSP uses the
> flattened device tree (at least the libbsd on BBB does). Therefore you
> have to load a dtb too. My U-Boot boot lines looks like follows:
> fatload mmc 0 0x80800000 rtems-app.img
> fatload mmc 0 0x88000000 am335x-boneblack.dtb
> bootm 0x80800000 - 0x88000000
> I create a SD-Card image with a script that is based on one that is (or
> was) contained some time back in the BSP. You can have a look here:
> https://gitlab.com/c-mauderer/rtems-bbb/blob/master/build/
> create-sdcardimage.sh
> The script does a lot of things that are not necessary any more (like
> copying a U-Boot to the SD card). Basically the necessary points would
> be to create a image and an uEnv.txt (with the lines from 78 to 83). You
> can use the dtb file that is provided by a FreeBSD or a Linux for BBB.
> Regarding debugging the application: I would strongly recommend to use
> some kind of hardware JTAG debugger. Some Beagle Bone variants have an
> on-board debugger (I think mainly the older white one). For others you
> can use hardware debuggers like quite a number of adapters supported by
> OpenOCD (FlySwatter2, simple FTDI-based ones, ...), Segger J-Link (in
> your case the EDU version) or whatever you find that can debug the BBB.
> It may be possible to use the libdebugger as a serial debugger. But I
> never used it so I'm not sure how well you can debug through the libbsd
> with it. I'm also not sure whether it works for the BBB. Chris Johns
> added the ARM support some time back. Maybe he can give you any hints if
> you want to try libdebugger.
> Best Regards
> Christian Mauderer
> > On Fri, Feb 23, 2018 at 11:25 PM, Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > Am 23.02.2018 um 05:17 schrieb Udit agarwal:
> > > Hi,
> > > Thanks for your help mentors,
> > > Since last time, I have managed to modify and execute hello world
> > > application on both the platforms, my local machine(Ubuntu 14.04) and
> > > BeagleBone Black.
> > > I have attached the screenshots and patch file as proof and  detailed
> > > logs can be found on these(1
> > > <https://gist.github.com/madaari/8aae37012d0d175b859c6471a5b13248
> > <https://gist.github.com/madaari/8aae37012d0d175b859c6471a5b13248>>
> > and 2
> > > <https://gist.github.com/madaari/a7f1d223fb0513e4890025fd1ba6184d
> > <https://gist.github.com/madaari/a7f1d223fb0513e4890025fd1ba6184d>>)
> > gists.
> > > Moreover, I went through all the mentioned projects, and found a few of
> > > them(Like extending support for PRU, integration of networking stack
> > > ,porting RTEMS on PocketBeagle etc) really interesting and doable
> > > withing the given time constraint!
> > > So, i thought of starting off by studying a bit about the networking
> > > stack, its implementation etc. Please recommend few resources from
> where
> > > i can explore this.
> > > Regards,
> > > Udit agarwal
> > Hello Udit,
> > it's great that you already have build and successfully executed the
> > example on BBB.
> > Regarding the network stack. First of all: Note that there are at least
> > three network stacks in RTEMS:
> > 1. The "old" one which is integrated into the RTEMS sources. This one
> > exists since quite some time in RTEMS. It is a fork of a really old
> > version of the FreeBSD network stack and it has been heavily adapted
> > during the time. I think there is a manual regarding this stack on the
> > docs.rtems.org <http://docs.rtems.org>. It has only IPv4 support.
> > 2. The "new" one which lives in it's own libbsd repository. That one is
> > a fork of the latest FreeBSD development version. One of the important
> > points during the development has been that the sources should be as
> > close as possible to the upstream FreeBSD sources. This makes it simpler
> > to keep up to the FreeBSD development. This one can IPv4 and IPv6 and
> > should be basically able to support everything FreeBSD does. Beneath
> > that it also brings in USB and SD-Card support and some other subsystems
> > of FreeBSD.
> > 3. I'm quite sure that I have seen some posts about the lwIP
> > (lightweight IP) stack used together with RTEMS.
> > Most network stack related projects on the open projects page refer to
> > the libbsd (second one in my list). So you most likely should
> > concentrate on that one.
> > The big disadvantage of the libbsd is that it heavily lacks
> > documentation. The main documentation is the one big libbsd.txt in the
> > source tree (https://git.rtems.org/rtems-libbsd/tree/libbsd.txt
> > <https://git.rtems.org/rtems-libbsd/tree/libbsd.txt>) and
> > some other files (like CONTRIBUGING.md).
> > If you want to work on the libbsd, I would suggest that you try to build
> > it for the Beagle Bone Black and for example access the SD card content.
> > For that I would suggest to take a look at the libbsd.txt and maybe at
> > the work of last years students (for the libbsd in 2017 that is mainly
> > Sichen Zhao). Please ask any question you have on the mailing list. And
> > please write down everything you learn and add it to the libbsd.txt. It
> > would be a really great start to improve that document.
> > Best regards
> > Christian Mauderer
> > > On Thu, Feb 22, 2018 at 12:28 AM, Christian Mauderer <
> list at c-mauderer.de <mailto:list at c-mauderer.de>
> > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> > >     Am 21.02.2018 um 00:14 schrieb Joel Sherrill:
> > >     > On Tue, Feb 20, 2018 at 3:23 PM, Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org> <mailto:gedare at rtems.org
> > <mailto:gedare at rtems.org>>
> > >     > <mailto:gedare at rtems.org <mailto:gedare at rtems.org>
> > <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>> wrote:
> > >     >     Hello and welcome,
> > >     >     For projects that intend to use a specific board, we
> > require that you
> > >     >     can demonstrate some proficiency with the board itself.
> > In this case,
> > >     >     you should be able to run RTEMS on the BBB first. Now,
> > there has been
> > >     >     significant progress made on BBB support, so hopefully
> > someone may
> > >     >     chime in with what else might remain to be done with it.
> > With a little
> > >     >     bit of digging, you should be able to find prior
> > students and mentors
> > >     >     for BBB related projects.
> > >     > My recollection is that the student working on Wifi got it
> > working
> > >     with a
> > >     > USB dongle on either the BBB or Pi. The Wifi stack still
> > needs work
> > >     > independent of any BSP and we have listed that as a project.
> > >     > But I thought the BBB was in pretty good shape overall. But
> > that's
> > >     just
> > >     > from memory.
> > >     > --joel
> > >     Hello,
> > >     I have been a mentor for Sichen last year. He has done some driver
> > >     support for the core RTEMS BSP of the BBB last year and he
> > ported the
> > >     necessary libbsd drivers to use a USB WiFi dongle on that
> > board. He also
> > >     put a lot of work into the encrypted WiFi support.
> > >     I think the year before Punit has worked on the BBB BSP.
> > >     Like Joel already said, the core BBB is quite well supported.
> > But there
> > >     are still some drivers like CAN, Ethernet or USB OTG (to name
> > a few)
> > >     that could be implemented. I've posted an update to the ticket
> > on BBB
> > >     (#2891) some weeks back.
> > >     There are also still two projects regarding the WiFi support
> > that could
> > >     be done. The BBB is a really good platform for that. That
> > would be the
> > >     tickets #3222 and #3223.
> > >     You can find the tickets linked on the open projects page in
> > the wiki.
> > >     Regards
> > >     Christian
> > >     >     Gedare
> > >     >     On Tue, Feb 20, 2018 at 1:56 PM, Udit agarwal
> > <dev.madaari at gmail.com <mailto:dev.madaari at gmail.com>
> > <mailto:dev.madaari at gmail.com <mailto:dev.madaari at gmail.com>>
> > <mailto:dev.madaari at gmail.com <mailto:dev.madaari at gmail.com>>>> wrote:
> > >     >     > Hi,
> > >     >     > I am Udit Agarwal(irc handle: madaari), pursuing my
> undergraduate
> > >     >     degree in
> > >     >     > Electronics Engineering from Netaji subash Institute of
> > >     >     Technology, India.
> > >     >     > I had some experience of TI-RTOS on MSP432(Cortex M)
> > >     >     microcontroller, with a
> > >     >     > pretty good grasp on Beagle Bone Black and other hardware
> stuff.
> > >     >     I'm pretty
> > >     >     > excited about the project of improving RTEMS support on
> Beagle
> > >     >     Bone Black,
> > >     >     > and would thus like to compete for it.
> > >     >     > Being already started with RTEMS documentation and the
> Hello World
> > >     >     project,
> > >     >     > I would like to know about any other resources i can
> consider
> > >     >     apart from
> > >     >     > documentation and RSB guide, for this specific BSP(Beagle
> Bone Black)?
> > >     >     > Thanks,
> > >     >     > Udit Agarwal
> > >     >     > _______________________________________________
> > >     >     > users mailing list
> > >     >     > users at rtems.org <mailto:users at rtems.org> <mailto:
> users at rtems.org
> > <mailto:users at rtems.org>>
> > >     <mailto:users at rtems.org <mailto:users at rtems.org>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>>
> > >     >     > http://lists.rtems.org/mailman/listinfo/users
> > <http://lists.rtems.org/mailman/listinfo/users>
> > <http://lists.rtems.org/mailman/listinfo/users>>
> > <http://lists.rtems.org/mailman/listinfo/users>>>
> > >     >     users mailing list
> users at rtems.org
> > >     > users mailing list
> > users mailing list
> > users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180226/ebcad4bc/attachment-0001.html>
