GSoC'18-Introduction
Mon Feb 26 21:09:50 UTC 2018
On 27/02/2018 07:54, Christian Mauderer wrote:
> Am 26.02.2018 um 18:01 schrieb Russell Haley:
>> On Mon, Feb 26, 2018 at 12:04 AM, Christian Mauderer
>> <christian.mauderer at embedded-brains.de> wrote:
>>> Hello Udit,
>>> Am 26.02.2018 um 08:30 schrieb Russell Haley:
>>>> On Sun, Feb 25, 2018 at 11:08 PM, Udit agarwal <dev.madaari at gmail.com> wrote:
>>>>> Hi,
>>>>> So, the error turned out to be due to missing dts only, after building the
>>>>> scripts again with FDT, both the I2C sample code(Logs:here),
>>>>> media01(Logs:here) example worked flawlessly, and thus i was able to read
>>>>> sd-card data. What could be my next possible task on libbsd?
>>> Most of the time, students are encouraged to fix some small bugs or
>>> create some small patches during this phase of GSoC. So you might want
>>> to do that.
A suggestion for a task is adding a check on targets that need an FDT blob
resident and to raise an error or warning rather than crash if not present?
A crash is an unpleasant error message.
