malloc info
Mikhail Svetkin
mikhail.svetkin at gmail.com
Fri Feb 9 08:51:09 UTC 2018
Thank you,
But why i can see different results?
shell function prints:
Total bytes free: 5351936
and
malloc_free_space return 1135128
Best regards,
Mikhail
On 9 February 2018 at 01:19, Chris Johns <chrisj at rtems.org> wrote:
> On 09/02/2018 00:59, Mikhail Svetkin wrote:
> > Hi all,
> > I am trying to investigate memory leak in my application.
> > I check malloc information via malloc_free_space
> > and rtems_shell_main_malloc_info and i see after some times that they
> have
> > different results.
> > For example:
> > rtems_shell_main_malloc_info prints 2mb and malloc_free_space prints 1mb
> > Which function should i use?
> There is a malloc shell command if you have the shell working or you could
> call
> the shell command directly:
> [/] # malloc
> C Program Heap and RTEMS Workspace are the same.
> Number of free blocks: 298
> Largest free block: 160667680
> Total bytes free: 160971752
> Number of used blocks: 6707
> Largest used block: 33554440
> Total bytes used: 97291328
> Size of the allocatable area in bytes: 258263080
> Minimum free size ever in bytes: 160926264
> Maximum number of free blocks ever: 314
> Maximum number of blocks searched ever: 90
> Lifetime number of bytes allocated: 1116295560
> Lifetime number of bytes freed: 1019006776
> Total number of searches: 28918650
> Total number of successful allocations: 28446143
> Total number of failed allocations: 0
> Total number of successful frees: 28439436
> Total number of successful resizes: 120
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20180209/6d955662/attachment-0002.html>
