RTEMS Toolchain building failed for ARM
zhang heng byone.heng at outlook.com
Thu Feb 22 08:08:12 UTC 2018
Dear,
  I have never installed Cygwin and minGW. when  creating a simple C file and compile it with gcc in the MSYS2 shell ,I find the error may be generated by ld.exe.
heng at heng-PC MINGW64 /h/Project/demo
$ gcc demo.c -o demo
F:/Program Files (x86)/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/7.3.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find F:/Program: Permission denied
F:/Program Files (x86)/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/7.3.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find Files: No such file or directory
F:/Program Files (x86)/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/7.3.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find (x86)/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/7.3.0/../../../../x86_64-w64-mingw32/lib/../lib/default-manifest.o: No such file or directory
collect2.exe: error: ld returned 1 exit status
What is more, the file which is in '/H/project/rtems/rsb/rtems/build/e2xwm1/expat-2.1.0' on my disk says the same error.
configure:2385: checking build system type
configure:2399: result: x86_64-w64-mingw32
configure:2419: checking host system type
configure:2432: result: x86_64-w64-mingw32
configure:2459: checking for x86_64-w64-mingw32-as
configure:2489: result: no
configure:2499: checking for as
configure:2515: found /mingw64/bin/as
configure:2526: result: as
configure:2551: checking for x86_64-w64-mingw32-dlltool
configure:2581: result: no
configure:2591: checking for dlltool
configure:2607: found /mingw64/bin/dlltool
configure:2618: result: dlltool
configure:2643: checking for x86_64-w64-mingw32-objdump
configure:2673: result: no
configure:2683: checking for objdump
configure:2699: found /mingw64/bin/objdump
configure:2710: result: objdump
configure:2801: checking how to print strings
configure:2828: result: printf
configure:2857: checking for x86_64-w64-mingw32-gcc
configure:2884: result: x86_64-w64-mingw32-gcc -O2 -pipe -I/H/Project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/include
configure:3153: checking for C compiler version
configure:3162: x86_64-w64-mingw32-gcc -O2 -pipe -I/H/Project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/include --version >&5
x86_64-w64-mingw32-gcc.exe (Rev1, Built by MSYS2 project) 7.3.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:3173: $? = 0
configure:3162: x86_64-w64-mingw32-gcc -O2 -pipe -I/H/Project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/include -v >&5
Using built-in specs.
COLLECT_GCC=F:\Program Files (x86)\msys2\mingw64\bin\x86_64-w64-mingw32-gcc.exe
COLLECT_LTO_WRAPPER=F:/Program\ Files\ (x86)/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/7.3.0/lto-wrapper.exe
Target: x86_64-w64-mingw32
Configured with: ../gcc-7.3.0/configure --prefix=/mingw64 --with-local-prefix=/mingw64/local --build=x86_64-w64-mingw32 --host=x86_64-w64-mingw32 --target=x86_64-w64-mingw32 --with-native-system-header-dir=/mingw64/x86_64-w64-mingw32/include --libexecdir=/mingw64/lib --enable-bootstrap --with-arch=x86-64 --with-tune=generic --enable-languages=c,lto,c++,objc,obj-c++,fortran,ada --enable-shared --enable-static --enable-libatomic --enable-threads=posix --enable-graphite --enable-fully-dynamic-string --enable-libstdcxx-time=yes --enable-libstdcxx-filesystem-ts=yes --disable-libstdcxx-pch --disable-libstdcxx-debug --disable-isl-version-check --enable-lto --enable-libgomp --disable-multilib --enable-checking=release --disable-rpath --disable-win32-registry --disable-nls --disable-werror --disable-symvers --with-libiconv --with-system-zlib --with-gmp=/mingw64 --with-mpfr=/mingw64 --with-mpc=/mingw64 --with-isl=/mingw64 --with-pkgversion='Rev1, Built by MSYS2 project' --with-bugurl=https://sourceforge.net/projects/msys2 --with-gnu-as --with-gnu-ld
Thread model: posix
gcc version 7.3.0 (Rev1, Built by MSYS2 project)
configure:3162: x86_64-w64-mingw32-gcc -O2 -pipe -I/H/Project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/include -V >&5
x86_64-w64-mingw32-gcc.exe: error: unrecognized command line option '-V'
x86_64-w64-mingw32-gcc.exe: fatal error: no input files
compilation terminated.
configure:3173: $? = 1
configure:3162: x86_64-w64-mingw32-gcc -O2 -pipe -I/H/Project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/include -qversion >&5
x86_64-w64-mingw32-gcc.exe: error: unrecognized command line option '-qversion'; did you mean '--version'?
configure:3193: checking whether the C compiler works
configure:3215: x86_64-w64-mingw32-gcc -O2 -pipe -I/H/Project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/include   -L/H/Project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/lib conftest.c  >&5
configure:3219: $? = 1
configure:3257: result: no
I have used the google to solve this issue, but no.....
Thanks  you,
Heng Zhang
On 2/19/2018 14:11,byone.heng<byone.heng at outlook.com><mailto:byone.heng at outlook.com> wrote:
Dear,
   I am busy in doing my homework some days ago,so I have no time to respond your letter.
   I have updated mingw-w64-x86_64-gcc to 7.3.0 and have installed all packages according to the manual (https://docs.rtems.org/branches/master/user/hosts/windows.html#installing-msys2)<https://docs.rtems.org/branches/master/user/hosts/windows.html#installing-msys2).the> . The following information is executed in msys2 minGW-64bit shell.
heng at heng-PC MINGW64 /h/Project/rtems/rsb/rtems
$ pacman -Q  python mingw-w64-x86_64-python2 mingw-w64-x86_64-gcc \
> bison cvs diffutils git make patch tar texinfo unzip
python 3.6.2-1
mingw-w64-x86_64-python2 2.7.14-5
mingw-w64-x86_64-gcc 7.3.0-1
bison 3.0.4-1
cvs 1.11.23-2
diffutils 3.5-1
git 2.16.1-1
make 4.2.1-1
patch 2.7.6-1
tar 1.30-1
texinfo 6.3-1
unzip 6.0-2
   Unfortunately, The error still exist.
Thanks you very much,
Heng Zhang.
On 2/12/2018 17:20,byone.heng<byone.heng at outlook.com><mailto:byone.heng at outlook.com> wrote:
Dear,
    Do you mean that I should install the x86_64-w64-mingw32-gcc in MSYS2 shell? but I cannot find this package.
Thanks you,
Heng Zhang
发自网易邮箱大师
On 2/9/2018 14:42,byone.heng<byone.heng at outlook.com><mailto:byone.heng at outlook.com> wrote:
Dear,
$ pacman -Q  mingw-w64-x86_64-gcc
mingw-w64-x86_64-gcc 6.2.0-2
$ gcc  -v
COLLECT_GCC=F:\Program Files (x86)\msys2\mingw64\bin\gcc.exe
(x86)/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/6.2.0/lto-wrapper.exe
Configured with: ../gcc-6.2.0/configure --prefix=/mingw64
--with-pkgversion='Rev2, Built by MSYS2 project'
Thread model: posix
gcc version 6.2.0 (Rev2, Built by MSYS2 project)
So I  am sure that the GCC have installed according to the above information.
but the error still exist.
configure: loading site script F:/Program Files (x86)/msys2/mingw64/etc/config.site
checking build system type... x86_64-w64-mingw32
checking host system type... x86_64-w64-mingw32
checking for x86_64-w64-mingw32-as... no
checking for as... as
checking for x86_64-w64-mingw32-dlltool... no
checking for dlltool... dlltool
checking for x86_64-w64-mingw32-objdump... no
checking for objdump... objdump
checking how to print strings... printf
checking for x86_64-w64-mingw32-gcc... x86_64-w64-mingw32-gcc -O2 -pipe
checking whether the C compiler works... no
configure: error: in `/H/Project/rtems/rsb/rtems/build/e2xwm1/expat-2.1.0':
configure: error: C compiler cannot create executables
See `config.log' for more details
shell cmd failed: sh -ex  /H/Project/rtems/rsb/rtems/build/e2xwm1/doit
error: building e2xwm1
Thanks,
zhang heng
发自网易邮箱大师
On 2/1/2018 11:10,zhang heng<byone.heng at outlook.com><mailto:byone.heng at outlook.com> wrote:
Dear All,
  I am attempting to build the RTEMS tool set according to RTEMS User Manual and Windows Host Tool Chain on windows10, but I meet with some troubles.
  I have done the following commands,
     $ ../source-builder/sb-check
   RTEMS Source Builder - Check, 4.11 (01ac76f2f90f)
   Environment is ok
but it generates an error when I execute such command:
$ ../source-builder/sb-set-builder --prefix=/h/Project/rtems/4.11 --jobs=none 4.11/rtems-arm
RTEMS Source Builder - Set Builder, 4.11 (4a87913b1451 modified)
Build Set: 4.11/rtems-arm
Build Set: 4.11/rtems-autotools.bset
Build Set: 4.11/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-w64-mingw32-1
building: autoconf-2.69-x86_64-w64-mingw32-1
config: tools/rtems-automake-1.12.6-1.cfg
package: automake-1.12.6-x86_64-w64-mingw32-1
building: automake-1.12.6-x86_64-w64-mingw32-1
cleaning: autoconf-2.69-x86_64-w64-mingw32-1
cleaning: automake-1.12.6-x86_64-w64-mingw32-1
Build Set: Time 0:06:46.911569
Build Set: 4.11/rtems-autotools-base.bset
reporting: tools/rtems-autoconf-2.69-1.cfg -> autoconf-2.69-x86_64-w64-mingw32-1.txt
reporting: tools/rtems-autoconf-2.69-1.cfg -> autoconf-2.69-x86_64-w64-mingw32-1.xml
reporting: tools/rtems-automake-1.12.6-1.cfg -> automake-1.12.6-x86_64-w64-mingw32-1.txt
reporting: tools/rtems-automake-1.12.6-1.cfg -> automake-1.12.6-x86_64-w64-mingw32-1.xml
installing: autoconf-2.69-x86_64-w64-mingw32-1 -> H:\Project\rtems\4.11
installing: automake-1.12.6-x86_64-w64-mingw32-1 -> H:\Project\rtems\4.11
Build Set: Time 0:06:58.049423
Build Set: Time 0:13:44.968990
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-w64-mingw32-1
building: expat-2.1.0-x86_64-w64-mingw32-1
Build FAILED
  See error report: rsb-report-expat-2.1.0-x86_64-w64-mingw32-1.txt
Build Set: Time 0:14:13.561418
Build FAILED
The following is the content of  rsb-report-expat-2.1.0-x86_64-w64-mingw32-1.txt:
 RTEMS Tools Project - Source Builder Error Report
 Build: error: building e2xwm1
 Command Line: ../source-builder/sb-set-builder --prefix=H:/Project/rtems/4.11 --jobs=none 4.11/rtems-arm
 Python: 2.7.12 (default, Sep 24 2016, 09:15:29)  [GCC 6.2.0 64 bit (AMD64)]
 git://git.rtems.org/rtems-source-builder.git/origin/4a87913b1451b4f0d56864ce6824bb2b4747353c-modified<http://git.rtems.org/rtems-source-builder.git/origin/4a87913b1451b4f0d56864ce6824bb2b4747353c-modified>
 Windows
Tail of the build log:
x -rwxrwxr-x  0 karl   karl     1990 Sep 30  2004 expat-2.1.0/expat.dsw
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/conftools/
x -rwxrwxr-x  0 karl   karl     2480 Apr  8  2006 expat-2.1.0/conftools/PrintPath
x -rwxrwxr-x  0 karl   karl      726 Sep 19  2000 expat-2.1.0/conftools/mkinstalldirs
x -rw-rw-r--  0 karl   karl     1442 Jan 19  2009 expat-2.1.0/conftools/expat.m4
x -rwxr-xr-x  0 karl   karl    35206 Mar 25  2012 expat-2.1.0/conftools/config.sub
x -rwxr-xr-x  0 karl   karl    13663 Mar 25  2012 expat-2.1.0/conftools/install-sh
x -rwxr-xr-x  0 karl   karl   282967 Mar 25  2012 expat-2.1.0/conftools/ltmain.sh
x -rw-rw-r--  0 karl   karl     2964 Oct  2  2001 expat-2.1.0/conftools/ac_c_bigendian_cross.m4
x -rwxr-xr-x  0 karl   karl    44504 Mar 25  2012 expat-2.1.0/conftools/config.guess
x -rwxrwxr-x  0 karl   karl     1266 May 18  2002 expat-2.1.0/conftools/get-version.sh
x -rw-rw-r--  0 karl   karl     5790 Mar 11  2012 expat-2.1.0/README
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/examples/
x -rw-rw-r--  0 karl   karl     2415 Jun  3  2007 expat-2.1.0/examples/outline.c
x -rw-rw-r--  0 karl   karl     1617 Jun  3  2007 expat-2.1.0/examples/elements.c
x -rw-rw-r--  0 karl   karl     3556 Feb 21  2012 expat-2.1.0/examples/elements.dsp
x -rw-rw-r--  0 karl   karl     3504 Feb 21  2012 expat-2.1.0/examples/outline.dsp
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/bcb5/
x -rw-rw-r--  0 karl   karl     4822 Dec  7  2002 expat-2.1.0/bcb5/expat_static.mak
x -rw-rw-r--  0 karl   karl     5044 Dec  7  2002 expat-2.1.0/bcb5/outline.mak
x -rw-rw-r--  0 karl   karl      247 Dec  7  2002 expat-2.1.0/bcb5/xmlwf.bpf
x -rw-rw-r--  0 karl   karl     1606 Dec  7  2002 expat-2.1.0/bcb5/all_projects.bpg
x -rw-rw-r--  0 karl   karl     5173 Oct 24  2003 expat-2.1.0/bcb5/expatw.mak
x -rw-rw-r--  0 karl   karl     5140 Oct 24  2003 expat-2.1.0/bcb5/expat.mak
x -rw-rw-r--  0 karl   karl     3783 Dec  7  2002 expat-2.1.0/bcb5/xmlwf.bpr
x -rw-rw-r--  0 karl   karl     5495 Jan  8  2004 expat-2.1.0/bcb5/libexpatw_mtd.def
x -rw-rw-r--  0 karl   karl      216 Dec  8  2002 expat-2.1.0/bcb5/expatw.bpf
x -rw-rw-r--  0 karl   karl      534 Jan 17  2003 expat-2.1.0/bcb5/makefile.mak
x -rw-rw-r--  0 karl   karl     3463 Dec  7  2002 expat-2.1.0/bcb5/outline.bpr
x -rw-rw-r--  0 karl   karl     4427 Dec 10  2002 expat-2.1.0/bcb5/expatw.bpr
x -rw-rw-r--  0 karl   karl      215 Dec  8  2002 expat-2.1.0/bcb5/expat.bpf
x -rw-rw-r--  0 karl   karl      553 Dec 10  2002 expat-2.1.0/bcb5/setup.bat
x -rw-rw-r--  0 karl   karl      153 Dec  7  2002 expat-2.1.0/bcb5/outline.bpf
x -rw-rw-r--  0 karl   karl     4576 Dec  7  2002 expat-2.1.0/bcb5/elements.bpr
x -rw-rw-r--  0 karl   karl     5078 Dec  7  2002 expat-2.1.0/bcb5/elements.mak
x -rw-rw-r--  0 karl   karl      155 Dec  7  2002 expat-2.1.0/bcb5/elements.bpf
x -rw-rw-r--  0 karl   karl     4301 Oct 24  2003 expat-2.1.0/bcb5/README.txt
x -rw-rw-r--  0 karl   karl      181 Dec  7  2002 expat-2.1.0/bcb5/expat_static.bpf
x -rw-rw-r--  0 karl   karl     4855 Dec 10  2002 expat-2.1.0/bcb5/expatw_static.mak
x -rw-rw-r--  0 karl   karl      181 Dec  7  2002 expat-2.1.0/bcb5/expatw_static.bpf
x -rw-rw-r--  0 karl   karl     5495 Jan  8  2004 expat-2.1.0/bcb5/libexpat_mtd.def
x -rw-rw-r--  0 karl   karl     3601 Dec  7  2002 expat-2.1.0/bcb5/expat_static.bpr
x -rw-rw-r--  0 karl   karl     4535 Dec 10  2002 expat-2.1.0/bcb5/expatw_static.bpr
x -rw-rw-r--  0 karl   karl     4039 Dec  8  2002 expat-2.1.0/bcb5/expat.bpr
x -rw-rw-r--  0 karl   karl     5145 Dec  7  2002 expat-2.1.0/bcb5/xmlwf.mak
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/m4/
x -rw-r--r--  0 karl   karl    11950 Mar 25  2012 expat-2.1.0/m4/ltoptions.m4
x -rw-r--r--  0 karl   karl     6126 Mar 25  2012 expat-2.1.0/m4/lt~obsolete.m4
x -rw-r--r--  0 karl   karl   281744 Mar 25  2012 expat-2.1.0/m4/libtool.m4
x -rw-r--r--  0 karl   karl     4372 Mar 25  2012 expat-2.1.0/m4/ltsugar.m4
x -rw-r--r--  0 karl   karl      686 Mar 25  2012 expat-2.1.0/m4/ltversion.m4
x -rwxrwxr-x  0 karl   karl     1512 Mar  5  2012 expat-2.1.0/ConfigureChecks.cmake
x -rw-rw-r--  0 karl   karl    11379 Mar 25  2012 expat-2.1.0/Changes
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/amiga/
x -rwxrwxr-x  0 karl   karl     6737 Aug  8  2009 expat-2.1.0/amiga/expat_68k_handler_stubs.c
x -rw-rw-r--  0 karl   karl     1395 Aug  8  2009 expat-2.1.0/amiga/expat_base.h
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/amiga/include/
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/amiga/include/libraries/
x -rw-rw-r--  0 karl   karl    16516 Jun  3  2007 expat-2.1.0/amiga/include/libraries/expat.h
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/amiga/include/interfaces/
x -rw-rw-r--  0 karl   karl     7930 Dec 24  2005 expat-2.1.0/amiga/include/interfaces/expat.h
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/amiga/include/proto/
x -rw-rw-r--  0 karl   karl     1335 Jun  3  2007 expat-2.1.0/amiga/include/proto/expat.h
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/amiga/include/inline4/
x -rw-rw-r--  0 karl   karl     6557 Dec 24  2005 expat-2.1.0/amiga/include/inline4/expat.h
x -rw-rw-r--  0 karl   karl    42000 Aug  8  2009 expat-2.1.0/amiga/expat_68k.c
x -rw-rw-r--  0 karl   karl    21979 Feb  1  2009 expat-2.1.0/amiga/expat_vectors.c
x -rwxrwxr-x  0 karl   karl     4133 Aug  8  2009 expat-2.1.0/amiga/expat_68k.h
x -rw-rw-r--  0 karl   karl    10427 Aug  8  2009 expat-2.1.0/amiga/Makefile
x -rw-rw-r--  0 karl   karl     3136 Aug  8  2009 expat-2.1.0/amiga/README.txt
x -rwxrwxr-x  0 karl   karl     1744 Aug  8  2009 expat-2.1.0/amiga/launch.c
x -rw-rw-r--  0 karl   karl    10742 Dec 24  2005 expat-2.1.0/amiga/expat.xml
x -rwxrwxr-x  0 karl   karl     5839 Aug  8  2009 expat-2.1.0/amiga/expat_lib.c
x -rwxrwxr-x  0 karl   karl   565580 Mar 25  2012 expat-2.1.0/configure
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/doc/
x -rw-rw-r--  0 karl   karl    94947 Mar 11  2012 expat-2.1.0/doc/reference.html
x -rw-rw-r--  0 karl   karl     2368 Jun  5  2007 expat-2.1.0/doc/valid-xhtml10.png
x -rw-rw-r--  0 karl   karl     1027 Jun  5  2007 expat-2.1.0/doc/expat.png
x -rw-rw-r--  0 karl   karl     1340 Jul 23  2004 expat-2.1.0/doc/style.css
x -rw-rw-r--  0 karl   karl     7895 Apr 30  2007 expat-2.1.0/doc/xmlwf.1
x -rw-rw-r--  0 karl   karl    13690 Jan 19  2009 expat-2.1.0/doc/xmlwf.sgml
x -rw-rw-r--  0 karl   karl      231 Jan 19  2009 expat-2.1.0/expat.pc.in<http://expat.pc.in/>
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/win32/
x -rw-rw-r--  0 karl   karl     1195 May  3  2007 expat-2.1.0/win32/MANIFEST.txt
x -rw-rw-r--  0 karl   karl     2804 Mar  4  2012 expat-2.1.0/win32/README.txt
x -rw-rw-r--  0 karl   karl     4337 Mar  4  2012 expat-2.1.0/win32/expat.iss
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/tests/
x -rw-rw-r--  0 karl   karl    49164 Mar  4  2012 expat-2.1.0/tests/runtests.c
x -rw-rw-r--  0 karl   karl     3038 Apr 30  2004 expat-2.1.0/tests/chardata.c
x -rwxrwxr-x  0 karl   karl     3557 Aug  4  2008 expat-2.1.0/tests/xmltest.sh
x -rw-rw-r--  0 karl   karl     2336 Feb 21  2012 expat-2.1.0/tests/minicheck.h
x -rw-rw-r--  0 karl   karl      185 Jan 28  2005 expat-2.1.0/tests/runtestspp.cpp
x -rw-rw-r--  0 karl   karl      570 Feb 26  2012 expat-2.1.0/tests/README.txt
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/tests/benchmark/
x -rw-rw-r--  0 karl   karl      820 Sep 30  2004 expat-2.1.0/tests/benchmark/benchmark.dsw
x -rw-rw-r--  0 karl   karl     2999 Feb 21  2012 expat-2.1.0/tests/benchmark/benchmark.dsp
x -rw-rw-r--  0 karl   karl      546 Jan  2  2006 expat-2.1.0/tests/benchmark/README.txt
x -rw-rw-r--  0 karl   karl     2798 Jun  3  2007 expat-2.1.0/tests/benchmark/benchmark.c
x -rw-rw-r--  0 karl   karl      791 Sep 30  2004 expat-2.1.0/tests/chardata.h
x -rw-rw-r--  0 karl   karl     4219 Jul  1  2006 expat-2.1.0/tests/minicheck.c
x -rwxrwxr-x  0 karl   karl     2735 Mar  5  2012 expat-2.1.0/expat_config.h.cmake
x -rwxrwxr-x  0 karl   karl     1768 Mar  5  2012 expat-2.1.0/CMake.README
x -rw-rw-r--  0 karl   karl     2518 Mar  5  2012 expat-2.1.0/MANIFEST
x -rw-rw-r--  0 karl   karl     2728 Mar 25  2012 expat-2.1.0/expat_config.h.in<http://expat_config.h.in/>
x drwxrwxr-x  0 karl   karl       0 Mar 25  2012 expat-2.1.0/vms/
x -rw-rw-r--  0 karl   karl     2080 Jan 29  2004 expat-2.1.0/vms/descrip.mms
x -rw-rw-r--  0 karl   karl     1199 Nov  3  2003 expat-2.1.0/vms/expat_config.h
x -rw-rw-r--  0 karl   karl      576 Jun  5  2002 expat-2.1.0/vms/README.vms
x -rw-rw-r--  0 karl   karl     7036 Mar 19  2012 expat-2.1.0/Makefile.in
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/xmlwf/
x -rwxrwxr-x  0 karl   karl      509 Dec 26  2005 expat-2.1.0/xmlwf/xmlfile.h
x -rwxrwxr-x  0 karl   karl      224 Jul  1  2002 expat-2.1.0/xmlwf/xmlurl.h
x -rwxrwxr-x  0 karl   karl     1790 Nov 13  2009 expat-2.1.0/xmlwf/readfilemap.c
x -rwxrwxr-x  0 karl   karl     2143 Jul  1  2002 expat-2.1.0/xmlwf/win32filemap.c
x -rwxrwxr-x  0 karl   karl     1274 Jun 28  2006 expat-2.1.0/xmlwf/unixfilemap.c
x -rwxrwxr-x  0 karl   karl      493 Jul  1  2002 expat-2.1.0/xmlwf/xmlmime.h
x -rwxrwxr-x  0 karl   karl     2912 Jul  1  2002 expat-2.1.0/xmlwf/ct.c
x -rwxrwxr-x  0 karl   karl     4130 Feb 21  2012 expat-2.1.0/xmlwf/xmlwf.dsp
x -rwxrwxr-x  0 karl   karl      500 Jul  1  2002 expat-2.1.0/xmlwf/filemap.h
x -rwxrwxr-x  0 karl   karl     1355 Aug  6  2006 expat-2.1.0/xmlwf/codepage.c
x -rwxrwxr-x  0 karl   karl     6082 Jun  3  2007 expat-2.1.0/xmlwf/xmlfile.c
x -rwxrwxr-x  0 karl   karl     3218 Jul  1  2002 expat-2.1.0/xmlwf/xmlmime.c
x -rwxrwxr-x  0 karl   karl    21212 Jan 19  2009 expat-2.1.0/xmlwf/xmlwf.c
x -rwxrwxr-x  0 karl   karl     8813 Aug 24  2002 expat-2.1.0/xmlwf/xmlwin32url.cxx
x -rwxrwxr-x  0 karl   karl      825 Apr 21  2000 expat-2.1.0/xmlwf/xmltchar.h
x -rwxrwxr-x  0 karl   karl      196 Jul  1  2002 expat-2.1.0/xmlwf/codepage.h
x -rw-rw-r--  0 karl   karl     4652 Mar  4  2012 expat-2.1.0/configure.in<http://configure.in/>
x drwxrwxr-x  0 karl   karl        0 Mar 25  2012 expat-2.1.0/lib/
x -rw-rw-r--  0 karl   karl     3144 Nov 27  2006 expat-2.1.0/lib/xmltok_ns.c
x -rw-rw-r--  0 karl   karl      797 Jun  3  2007 expat-2.1.0/lib/amigaconfig.h
x -rw-rw-r--  0 karl   karl    11184 Dec 23  2005 expat-2.1.0/lib/xmltok.h
x -rw-rw-r--  0 karl   karl     3364 Jun  2  2006 expat-2.1.0/lib/expat_external.h
x -rw-rw-r--  0 karl   karl     1830 Jul  2  2002 expat-2.1.0/lib/iasciitab.h
x -rw-rw-r--  0 karl   karl     4599 Jul  9  2002 expat-2.1.0/lib/Makefile.MPW
x -rw-rw-r--  0 karl   karl     2028 May 12  2007 expat-2.1.0/lib/libexpat.def
x -rw-rw-r--  0 karl   karl      709 Dec 17  2005 expat-2.1.0/lib/winconfig.h
x -rw-rw-r--  0 karl   karl     7050 Sep 19  2000 expat-2.1.0/lib/nametab.h
x -rw-rw-r--  0 karl   karl     2028 Nov 27  2006 expat-2.1.0/lib/internal.h
x -rw-rw-r--  0 karl   karl    32475 Jan 31  2009 expat-2.1.0/lib/xmlrole.c
x -rw-rw-r--  0 karl   karl     4971 Feb 21  2012 expat-2.1.0/lib/expatw.dsp
x -rw-rw-r--  0 karl   karl     1760 Jul  2  2002 expat-2.1.0/lib/asciitab.h
x -rw-rw-r--  0 karl   karl     1763 Jul  2  2002 expat-2.1.0/lib/utf8tab.h
x -rw-rw-r--  0 karl   karl     2028 May 12  2007 expat-2.1.0/lib/libexpatw.def
x -rw-rw-r--  0 karl   karl   197613 Mar 11  2012 expat-2.1.0/lib/xmlparse.c
x -rw-rw-r--  0 karl   karl    41405 Jan 31  2009 expat-2.1.0/lib/xmltok.c
x -rw-rw-r--  0 karl   karl     1985 May  8  2007 expat-2.1.0/lib/ascii.h
x -rw-rw-r--  0 karl   karl      661 Sep 22  2000 expat-2.1.0/lib/xmltok_impl.h
x -rw-rw-r--  0 karl   karl     1813 Jul  2  2002 expat-2.1.0/lib/latin1tab.h
x -rw-rw-r--  0 karl   karl     4325 May  3  2007 expat-2.1.0/lib/expatw_static.dsp
x -rw-rw-r--  0 karl   karl     1325 Nov  3  2003 expat-2.1.0/lib/macconfig.h
x -rw-rw-r--  0 karl   karl     4901 Feb 21  2012 expat-2.1.0/lib/expat.dsp
x -rw-rw-r--  0 karl   karl     3023 Nov 13  2002 expat-2.1.0/lib/xmlrole.h
x -rw-rw-r--  0 karl   karl    44554 Feb 21  2012 expat-2.1.0/lib/xmltok_impl.c
x -rw-rw-r--  0 karl  karl     4254 Feb 21  2012 expat-2.1.0/lib/expat_static.dsp
x -rw-rw-r--  0 karl   karl    41752 Mar  4  2012 expat-2.1.0/lib/expat.h
x -rw-rw-r--  0 karl   karl   304569 Mar 25  2012 expat-2.1.0/aclocal.m4
+ cd expat-2.1.0
+ chmod -R a+rX,g-w,o-w .
+ cd /H/project/rtems/rsb/rtems/build/e2xwm1
+ SB_CXC=no
==> clean %{buildroot}: /H/project/rtems/rsb/rtems/build/tmp/expat-2.1.0-x86_64-w64-mingw32-1-root-heng
+ echo '==> clean %{buildroot}: /H/project/rtems/rsb/rtems/build/tmp/expat-2.1.0-x86_64-w64-mingw32-1-root-heng'
+ rm -rf /H/project/rtems/rsb/rtems/build/tmp/expat-2.1.0-x86_64-w64-mingw32-1-root-heng
+ /bin/mkdir -p /H/project/rtems/rsb/rtems/build/tmp/expat-2.1.0-x86_64-w64-mingw32-1-root-heng
==> %build:
+ echo '==> %build:'
++ pwd
+ build_top=/H/project/rtems/rsb/rtems/build/e2xwm1
+ cd expat-2.1.0
+ test x86_64-w64-mingw32 '!=' x86_64-w64-mingw32
+ LDFLAGS=-L/H/project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/lib
++ echo 'x86_64-w64-mingw32-gcc -O2 -pipe -I/H/project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/include'
++ sed -e 's,-std=gnu99 ,,'
+ CC='x86_64-w64-mingw32-gcc -O2 -pipe -I/H/project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/include'
++ echo 'x86_64-w64-mingw32-g++ -O2 -pipe -I/H/project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/include'
+ CXX='x86_64-w64-mingw32-g++ -O2 -pipe -I/H/project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/include'
+ CC_FOR_BUILD='x86_64-w64-mingw32-gcc -O2 -pipe -I/H/project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/include'
+ CXX_FOR_BUILD='x86_64-w64-mingw32-g++ -O2 -pipe -I/H/project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/include'
+ export CC CXX CFLAGS CXXFLAGS LDFLAGS
+ export CC_FOR_HOST CXX_FOR_HOST CFLAGS_FOR_HOST CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST
+ export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD LDFLAGS_FOR_BUILD
+ ./configure --build=x86_64-w64-mingw32 --host=x86_64-w64-mingw32 --verbose --prefix=/H/Project/rtems/4.11 --bindir=/H/Project/rtems/4.11/bin --exec-prefix=/H/Project/rtems/4.11 --includedir=/H/Project/rtems/4.11/include --libdir=/H/Project/rtems/4.11/lib --mandir=/H/Project/rtems/4.11/share/man --infodir=/H/Project/rtems/4.11/share/info
checking for x86_64-w64-mingw32-gcc... x86_64-w64-mingw32-gcc -O2 -pipe -I/H/project/rtems/rsb/rtems/build/tmp/sb-heng/4.11/rtems-arm/H/Project/rtems/4.11/include
configure: error: in `/H/project/rtems/rsb/rtems/build/e2xwm1/expat-2.1.0':
shell cmd failed: sh -ex  /H/project/rtems/rsb/rtems/build/e2xwm1/doit
Thanks  in advance,
ToSeven
发送自 Windows 10 版邮件<https://go.microsoft.com/fwlink/?LinkId=550986>应用
URL: <http://lists.rtems.org/pipermail/users/attachments/20180222/7be8a342/attachment-0002.html>
