GSoC'18-Introduction
Udit agarwal
dev.madaari at gmail.com
Sun Feb 25 07:41:00 UTC 2018
Hi,
I did build libbsd for beagleboneBlack and executed selectpollkqueue01 test
successfully.(Logs:here
<https://gist.github.com/madaari/ae7b3334514a9aec3b063eaa3a0dcd05>)
However, while trying to access SD card, media01 test failed with an error
"fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION) " (Logs:here
<https://gist.github.com/madaari/c6d524bc06e896359f9535d90c0a447a>)
I tried debugging the script, by putting printf statements in various
functions, but it seems like it's failing even before entering test_main().
Also, is there a better method with which we can debug RTEMS scripts?
Thanks,
Udit Agarwal
On Fri, Feb 23, 2018 at 11:25 PM, Christian Mauderer <list at c-mauderer.de>
wrote:
> Am 23.02.2018 um 05:17 schrieb Udit agarwal:
> > Hi,
> > Thanks for your help mentors,
> > Since last time, I have managed to modify and execute hello world
> > application on both the platforms, my local machine(Ubuntu 14.04) and
> > BeagleBone Black.
> > I have attached the screenshots and patch file as proof and detailed
> > logs can be found on these(1
> > <https://gist.github.com/madaari/8aae37012d0d175b859c6471a5b13248> and 2
> > <https://gist.github.com/madaari/a7f1d223fb0513e4890025fd1ba6184d>)
> gists.
> > Moreover, I went through all the mentioned projects, and found a few of
> > them(Like extending support for PRU, integration of networking stack
> > ,porting RTEMS on PocketBeagle etc) really interesting and doable
> > withing the given time constraint!
> > So, i thought of starting off by studying a bit about the networking
> > stack, its implementation etc. Please recommend few resources from where
> > i can explore this.
> > Regards,
> > Udit agarwal
> Hello Udit,
> it's great that you already have build and successfully executed the
> example on BBB.
> Regarding the network stack. First of all: Note that there are at least
> three network stacks in RTEMS:
> 1. The "old" one which is integrated into the RTEMS sources. This one
> exists since quite some time in RTEMS. It is a fork of a really old
> version of the FreeBSD network stack and it has been heavily adapted
> during the time. I think there is a manual regarding this stack on the
> docs.rtems.org. It has only IPv4 support.
> 2. The "new" one which lives in it's own libbsd repository. That one is
> a fork of the latest FreeBSD development version. One of the important
> points during the development has been that the sources should be as
> close as possible to the upstream FreeBSD sources. This makes it simpler
> to keep up to the FreeBSD development. This one can IPv4 and IPv6 and
> should be basically able to support everything FreeBSD does. Beneath
> that it also brings in USB and SD-Card support and some other subsystems
> of FreeBSD.
> 3. I'm quite sure that I have seen some posts about the lwIP
> (lightweight IP) stack used together with RTEMS.
> Most network stack related projects on the open projects page refer to
> the libbsd (second one in my list). So you most likely should
> concentrate on that one.
> The big disadvantage of the libbsd is that it heavily lacks
> documentation. The main documentation is the one big libbsd.txt in the
> source tree (https://git.rtems.org/rtems-libbsd/tree/libbsd.txt) and
> some other files (like CONTRIBUGING.md).
> If you want to work on the libbsd, I would suggest that you try to build
> it for the Beagle Bone Black and for example access the SD card content.
> For that I would suggest to take a look at the libbsd.txt and maybe at
> the work of last years students (for the libbsd in 2017 that is mainly
> Sichen Zhao). Please ask any question you have on the mailing list. And
> please write down everything you learn and add it to the libbsd.txt. It
> would be a really great start to improve that document.
> Best regards
> Christian Mauderer
> > On Thu, Feb 22, 2018 at 12:28 AM, Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > Am 21.02.2018 um 00:14 schrieb Joel Sherrill:
> > > On Tue, Feb 20, 2018 at 3:23 PM, Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>
> > > <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>> wrote:
> > > Hello and welcome,
> > > For projects that intend to use a specific board, we require
> that you
> > > can demonstrate some proficiency with the board itself. In
> this case,
> > > you should be able to run RTEMS on the BBB first. Now, there
> has been
> > > significant progress made on BBB support, so hopefully someone
> may
> > > chime in with what else might remain to be done with it. With
> a little
> > > bit of digging, you should be able to find prior students and
> mentors
> > > for BBB related projects.
> > > My recollection is that the student working on Wifi got it working
> > with a
> > > USB dongle on either the BBB or Pi. The Wifi stack still needs work
> > > independent of any BSP and we have listed that as a project.
> > > But I thought the BBB was in pretty good shape overall. But that's
> > just
> > > from memory.
> > > --joel
> > Hello,
> > I have been a mentor for Sichen last year. He has done some driver
> > support for the core RTEMS BSP of the BBB last year and he ported the
> > necessary libbsd drivers to use a USB WiFi dongle on that board. He
> also
> > put a lot of work into the encrypted WiFi support.
> > I think the year before Punit has worked on the BBB BSP.
> > Like Joel already said, the core BBB is quite well supported. But
> there
> > are still some drivers like CAN, Ethernet or USB OTG (to name a few)
> > that could be implemented. I've posted an update to the ticket on BBB
> > (#2891) some weeks back.
> > There are also still two projects regarding the WiFi support that
> could
> > be done. The BBB is a really good platform for that. That would be
> the
> > tickets #3222 and #3223.
> > You can find the tickets linked on the open projects page in the
> wiki.
> > Regards
> > Christian
> > > Gedare
> > > On Tue, Feb 20, 2018 at 1:56 PM, Udit agarwal <
> dev.madaari at gmail.com <mailto:dev.madaari at gmail.com>
> > > <mailto:dev.madaari at gmail.com <mailto:dev.madaari at gmail.com>>>
> wrote:
> > > > Hi,
> > > > I am Udit Agarwal(irc handle: madaari), pursuing my
> undergraduate
> > > degree in
> > > > Electronics Engineering from Netaji subash Institute of
> > > Technology, India.
> > > > I had some experience of TI-RTOS on MSP432(Cortex M)
> > > microcontroller, with a
> > > > pretty good grasp on Beagle Bone Black and other hardware
> stuff.
> > > I'm pretty
> > > > excited about the project of improving RTEMS support on
> Beagle
> > > Bone Black,
> > > > and would thus like to compete for it.
> > > > Being already started with RTEMS documentation and the Hello
> World
> > > project,
> > > > I would like to know about any other resources i can consider
> > > apart from
> > > > documentation and RSB guide, for this specific BSP(Beagle
> Bone Black)?
> > > > Thanks,
> > > > Udit Agarwal
> > > > _______________________________________________
> > > > users mailing list
> > > > users at rtems.org <mailto:users at rtems.org>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>
> > > > http://lists.rtems.org/mailman/listinfo/users
> > <http://lists.rtems.org/mailman/listinfo/users>
> > <http://lists.rtems.org/mailman/listinfo/users>>
> > > users mailing list
> > > users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20180225/5bae2134/attachment-0002.html>
