change bsp
Wed Jan 10 15:36:21 UTC 2018
Hello,
On Tue, Jan 2, 2018 at 8:35 AM, bin.wang at qkmtech.com
<bin.wang at qkmtech.com> wrote:
> hi
> 1:i want to change the bsp according to the zynq zedboard。it only has
> console driver and i2c driver。 so i want to add some drviers i used in
> bare-metal software before (such as gpio)。i do not know how to start。
You can add the drivers to the BSP. Probably you can just make your
baremetal drivers work correctly by initializing them at the right
time.
> please give me some advice。
> i find the function in bootcard.c       "rtems_initialize_device_drivers"
> i think i need add code here, but the bsp i used installed as lib.    so ,
> can i  change the source code?
> i do not understand the RTEMS_DRVMGR_STARTUP level 1,2,3,4   ,is there a
> example to add my device driver to the rtems architecture?
This DRVMGR stuff interacts with the cpukit/libdrvmgr, which is from
Gaisler folks and mostly supports Sparc targets.
What version of rtems do you use? I guess it is 4.11.x?
You could initialize baremetal drivers at any point even in your
application itself.
> void rtems_initialize_device_drivers(void)
>    *  Initialize all the device drivers and initialize the MPCI layer.
>    *  NOTE:  The MPCI may be build upon a device driver.
>   #ifdef RTEMS_DRVMGR_STARTUP
>   /* BSPs has already registered their "root bus" driver in the
>    * bsp_predriver hook or so.
>    * Init Drivers to Level 1, constraints:
>    *   - Interrupts and system clock timer does not work.
>    *   - malloc() work, however other memory services may not
>    *     have been initialized yet.
>    *   - initializes most basic stuff
>    * Typical setup in Level 1:
>    *   - Find most devices in system, do PCI scan and configuration.
>    *   - Reset hardware if needed.
>    *   - Install IRQ driver
>    *   - Install Timer driver
>    *   - Install console driver and debug printk()
>    *   - Install extra memory.
>   _DRV_Manager_init_level(1);
>   bsp_driver_level_hook(1);
>   #endif
>   /* Initialize I/O drivers.
>    * Driver Manager note:
>    * All drivers may not be registered yet. Drivers will dynamically
>    * be initialized when registered in level 2,3 and 4.
>   _IO_Initialize_all_drivers();
>   /* Init Drivers to Level 2, constraints:
>    *  - Interrupts can be registered and enabled.
>    *  - System Clock is running
>    *  - Console may be used.
>    * This is typically where drivers are initialized
>    * for the first time.
>   _DRV_Manager_init_level(2);
>   bsp_driver_level_hook(2);
>   /* Init Drivers to Level 3
>    * This is typically where normal drivers are initialized
>    * for the second time, they may depend on other drivers
>    * API inited in level 2
>   _DRV_Manager_init_level(3);
>   bsp_driver_level_hook(3);
>   /* Init Drivers to Level 4,
>    * Init drivers that depend on services initialized in Level 3
>   _DRV_Manager_init_level(4);
>   bsp_driver_level_hook(4);
>   #endif
>   #if defined(RTEMS_MULTIPROCESSING)
>     if ( _System_state_Is_multiprocessing ) {
>       _MPCI_Initialization();
>       _MPCI_Internal_packets_Send_process_packet(
> MPCI_PACKETS_SYSTEM_VERIFY
>   #endif
>    *  Run the APIs and BSPs postdriver hooks.
>    *  The API extensions are supposed to create user initialization tasks.
>   _API_extensions_Run_postdriver();
> 2:another question is how can i enable the interrupt? in the init task is
> ok?
Interrupts will be already enabled when Init() is called. They get
turned on during the RTEMS initialization sequence.
> ________________________________
> users mailing list
> users at rtems.org
