the difference between posix user and c user
bin.wang at qkmtech.com
Thu Jan 11 01:29:02 UTC 2018
think you very much.
as you said:
>POSIX and ISO-C tend to go together.
>With RTEMS, you can also use ISO-C with the "Classic API", which
>consists of interface functions accessible from C programs as
>described in the "C User Guide".
Does it mean that i can just use ISO-c? so ,i think I do not need care about posix API because i think i use the classic api is enough for me . is it right?
>Most new development and ports of existing software probably use POSIX
>anyway, except for the simplest applications. This configure option
>was provided historically as a way to avoid compiling the POSIX
>library into an application, but modern compilers are able to remove
>the unused code any way.
i think i understand what you said in this part . if i use the --enable posix in the configure , but i do not use the posix api, then ,the compiler will not use the unused code .
thanks
Date: 2018-01-11 00:50
To: bin.wang at qkmtech.com
CC: Chris Johns; Users
Subject: Re: Re: the difference between posix user and c user
On Thu, Dec 28, 2017 at 9:35 PM, bin.wang at qkmtech.com
<bin.wang at qkmtech.com> wrote:
> is the posix api and the c api used together?
> sorry . i am also confused about this two things . because i find that when
> i config the rtems kernel ,there is a option which is --enable posix.
> ________________________________
> From: bin.wang at qkmtech.com
> Date: 2017-12-29 09:25
> To: Chris Johns; Users
> i google the posix .now i know that posix is the abbreviation of "the
> Portable Operating System Interface" it is for software compatibility with
> variants of Unix and other operating systems
> but you said, "POSIX and the Classic API are both C APIs."
> than i think the posix is packaged on the basis of the standard C, is it
> right ?
> the classic api is the standard c interface , is it right?
> best wishes
> From: Chris Johns
> Date: 2017-12-29 02:18
> To: users
> Subject: Re: the difference between posix user and c user
> On 29/12/17 12:00 am, bin.wang at qkmtech.com wrote:
>> hi everyone:
>> i am new to linux and rtems. i do not understand
>> what the difference between posix user and c user .
>> i am confused about these two concept. which condition i should choose
>> posix ?
>> which condition i should choose c ?
> This is a good question and it is understandable why you do not understand
> the
> difference. The reason is specific to RTEMS and relates to it's history.
> The original RTEMS was written in Ada and C and the C API is what we now
> call
> the Classic API. It's manual was called the C User Guide hence the name.
> The Ada version of RTEMS was removed from the source tree and POSIX came a
> while
> later.
> POSIX and the Classic API are both C APIs. The C User manual is now called
> the
> RTEMS Classic API Guide. See:
> https://docs.rtems.org/
> Chris
> users mailing list
> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180111/cf80f3b8/attachment.html>
