the difference between posix user and c user
Thu Jan 11 15:04:48 UTC 2018
On Wed, Jan 10, 2018 at 8:29 PM, bin.wang at qkmtech.com
<bin.wang at qkmtech.com> wrote:
> think you very much.
> as  you said:
>>POSIX and ISO-C tend to go together.
>>With RTEMS, you can also use ISO-C with the "Classic API", which
>>consists of interface functions accessible from C programs as
>>described in the "C User Guide".
> Does it mean that i can just use ISO-c?  so ,i think  I do not  need care
> about posix API because i think  i use the classic api  is enough for me  .
> is it right?
Sure.
>>Most new development and ports of existing software probably use POSIX
>>anyway, except for the simplest applications. This configure option
>>was provided historically as a way to avoid compiling the POSIX
>>library into an application, but modern compilers are able to remove
>>the unused code any way.
> i think i understand what you said  in this part . if i use the  --enable
> posix in the  configure , but i do not use the posix api, then ,the compiler
> will not use the unused code .
Correct.
> thanks
> ________________________________
> From: Gedare Bloom
> Date: 2018-01-11 00:50
> To: bin.wang at qkmtech.com
> CC: Chris Johns; Users
> Subject: Re: Re: the difference between posix user and c user
> On Thu, Dec 28, 2017 at 9:35 PM, bin.wang at qkmtech.com
>> is the posix api and the c api used together?
>> sorry . i am also confused about this two things . because i find that
>> when
>> i config the rtems kernel ,there is a option which is  --enable posix.
>> From: bin.wang at qkmtech.com
>> Date: 2017-12-29 09:25
>> To: Chris Johns; Users
>> i google the posix .now i know that posix is the abbreviation of "the
>> Portable Operating System Interface" it is for software compatibility with
>> variants of Unix and other operating systems
>> but you said, "POSIX and the Classic API are both C APIs."
>> than i think the posix is packaged on the basis of the standard C, is it
>> right ?
>> the classic api is the standard c interface , is it right?
>> best wishes
>> From: Chris Johns
>> Date: 2017-12-29 02:18
>> To: users
>> Subject: Re: the difference between posix user and c user
>> On 29/12/17 12:00 am, bin.wang at qkmtech.com wrote:
>>> hi everyone:
>>> i am new to linux and rtems. i do not understand
>>> what the difference between posix user and c user .
>>> i am confused about these two concept. which condition i should choose
>>> posix ?
>>> which condition i should choose c ?
>> This is a good question and it is understandable why you do not understand
>> the
>> difference. The reason is specific to RTEMS and relates to it's history.
>> The original RTEMS was written in Ada and C and the C API is what we now
>> call
>> the Classic API. It's manual was called the C User Guide hence the name.
>> The Ada version of RTEMS was removed from the source tree and POSIX came a
>> while
>> later.
>> POSIX and the Classic API are both C APIs. The C User manual is now called
>> the
>> RTEMS Classic API Guide. See:
>> https://docs.rtems.org/
>> Chris
>> users mailing list
>> users at rtems.org
>> users mailing list
>> users at rtems.org
