smp support
bin.wang at qkmtech.com
Fri Jan 12 01:12:44 UTC 2018
Did you add an extra > character for your response? It is messing with
my email client, which interprets these as "reply" nesting...
> sorry , i will add an extra > character for my response on later reply.
>i have know what you said ,thank you very much
Date: 2018-01-11 23:09
To: bin.wang at qkmtech.com
CC: Chris Johns; Users
Subject: Re: Re: smp support
On Wed, Jan 10, 2018 at 8:48 PM, bin.wang at qkmtech.com
<bin.wang at qkmtech.com> wrote:
>> another question:
>> if i use the smp configuration macro define,am i still need to do the
>> mutiprocessor configuration macro define for confdef.h ?
> With SMP you have to enable SMP when you configure/build RTEMS, and
> you need to provide the CPP configuration macros to set up the SMP
> system and schedulers.
>>> what the CPP means?
C Preprocessor.
>>>in CONFIGURING A SYSTEM chapter in c user doc, i find the two
>>> configurations items . one is 24.22 SMP Specific Configuration Parameters
>>> ,another is 24.24 Multiprocessing Configuration
>>>what i want to ask is if i want to use smp, do i need use the
>>> Multiprocessing Configuration? or i just need use SMP Specific
>>> Configuration Parameters and do not need care about >>the Multiprocessing
>>> Configuration.
You do not need to care about Multiprocessing Configuration.
> "SMP means all cores are treated equally by the operating system."
> "AMP means cores are not treated the same by the OS, which can cover a lot
> of heterogeneous behavior."
>>>i know what you said
>>>so the basic problem which confused me is the difference betweent
>>> Multiprocessing Configuration and SMP Configuration, not the concept of amp
>>> and smp
>>>in my point of view ,no matter AMP or SMP is all called Multiprocessing
>>> because they all use the muticore .is it right ? so if i want to use AMP
>>> mode ,than i need >>just Multiprocessing Configuration?
There is not support for AMP out of the box with RTEMS as far as I
know. This "Multiprocessing Configuration" stuff is about how to run a
distributed system of multiple RTEMS images, one on each processor,
that share a global object namespace. It is not the same as how to run
a single RTEMS image that manages multiple processors.
>>>if i want to use SMP mode,than i need Multiprocessing Configuration and
>>> SMP Configuration ?
> ________________________________
> From: Gedare Bloom
> Date: 2018-01-11 00:43
> On Fri, Dec 29, 2017 at 3:55 AM, bin.wang at qkmtech.com
>> thanks
>> but i still confused about the smp configuration and the mutiprocessor
>> configuration .
>> for example. for zynq ,they has two arm core. if i use the mutiprocessor
>> configuration , Is rtems use the two cores in amp mode ? is the rtems
>> manage the two cores? if rtems manages two cores,i think it is in smp mode
>> because i think the concept of smp mode is the one system can manage
>> muticores which are same cpu architecture。this is conflictive for my
>> point
>> of view
> lot of heterogeneous behavior.
> RTEMS provides SMP capability.
>> i think amp mode is rtems run in one core, another core is bare-metal or
>> linux. but the mutiprocessor configuration let me confused, it said as
>> follows
>> "The RTEMS multiprocessor execution model is multiple instruction streams
>> with multiple data
>> streams (MIMD). This execution model has each of the processors executing
>> code independent
>> of the other processors. Because of this parallelism, the application
>> designer can more easily
>> guarantee deterministic behavior."
> This statement is true regardless of SMP/AMP: in either case, program
> code runs independent of other processors.
>> is it means one rtems system instance run in one core ,and another rtems
>> system instance run in another core? and they can excute code
>> independent?
>> sorry, i think maybe i have some concept confused
> One RTEMS instances executes across both cores, and both cores can
> execute code independent. It is possible for both cores to be
> executing OS functions simultaneously, or one core to execute OS code
> while another runs application, or both cores to execute application
> code in parallel.
>> if just one rtems run in two core , how to put code into different core to
>> run ? how to realize the parrallelism?
> If you select RTEMS with SMP and provide scheduler with two cores, the
> scheduler will assign tasks/threads to the cores according to its
> scheduler policy/algorithm.
>> another question:
>> From: Chris Johns
>> Date: 2017-12-29 14:21
>> To: bin.wang at qkmtech.com; Users
>> Subject: Re: smp support
>> On 29/12/17 12:16 pm, bin.wang at qkmtech.com wrote:
>>> thanks a lot .
>>> i have another question , if i use the smp, can i use the interrupt of
>>> rtems?
>>> which i want to interrupt period of hard real time of 125us.
>> Yes you can.
>>> i do not know the difference of the bare-metal interrupt and the rtems
>>> interrupt
>>> . is the rtems interrupt have performance loss of the hard real-time?
>> The interrupt overhead will have the same overhead each time and its
>> deterministic behaviour will depend on the other interrupts in your system
>> and
>> their priority. The performance will depend on what you need to do in the
>> interrupt.
>>> what the schedule method of smp use? is it can affect the interrupt
>>> performance?
>> That depends on your application.
>> Chris
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180112/36beb871/attachment-0001.html>
