Device Interrupt Handler CPU Load Anaysis Method.
Thomas Kim
thomas73.kim at gmail.com
Wed Jan 17 06:35:41 UTC 2018
Dear Huber,
I think that there is limitation using RTEMS profiling feature, too.
Instead of this method, I am using hardware assitance method using GPIO
signal as like below;
void bsp_interrupt_dispatch(void)
volatile gic_cpuif *cpuif = GIC_CPUIF;
uint32_t icciar = cpuif->icciar;
rtems_vector_number vector = GIC_CPUIF_ICCIAR_ACKINTID_GET(icciar);
rtems_vector_number spurious = 1023;
if (vector != spurious) {
uint32_t psr = _ARMV4_Status_irq_enable();
gpio01_19_high(); /* Signal High */
bsp_interrupt_handler_dispatch(vector);
gpio01_19_low(); /* Signal Low */
_ARMV4_Status_restore(psr);
cpuif->icceoir = icciar;
When I check GPIO signal using digital scope, I can check average duty
cycle.
Do you think that it is good method ?
There is additional question.
I think that CPU time percentage using "cpuuse" is CPU time consuming value
except interrupt handler consuming time.
Is it correct ?
Best Regards,
Thomas
2018-01-12 15:03 GMT+09:00 Sebastian Huber <
sebastian.huber at embedded-brains.de>:
> On 12/01/18 02:38, Thomas Kim wrote:
>> Dear Sir,
>> As I checked until now, thread(task, pthread) cpu load analysis method
>> using "cpuuse" is perfect !
>> At this time, I am doing multiple device interrupt hander stress testing.
>> but, there is not CPU load anaysis method about multiple device interrupt
>> handler.
>> Is there any method for checking CPU load about multiple device interrupt
>> handlers ?
> The is limited support for this. You can try to use enable the profiling
> option:
> cpukit/sapi/include/rtems/profiling.h
> For interrupt profiling a BSP support is necessary. I think it is only
> implemented on ARM, PowerPC and SPARC currently.
> The RTEMS trace linker is also an option.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20180117/776e6301/attachment.html>
