Device Interrupt Handler CPU Load Anaysis Method.
Wed Jan 17 06:50:51 UTC 2018
On 17/01/18 07:35, Thomas Kim wrote:
> Dear Huber,
> I think that there is limitation using RTEMS profiling feature, too.
There are always limitations.
> Instead of this method, I am using hardware assitance method using
> GPIO signal as like below;
> void bsp_interrupt_dispatch(void)
>   volatile gic_cpuif *cpuif = GIC_CPUIF;
>   uint32_t icciar = cpuif->icciar;
>   rtems_vector_number vector = GIC_CPUIF_ICCIAR_ACKINTID_GET(icciar);
>   rtems_vector_number spurious = 1023;
>   if (vector != spurious) {
>     uint32_t psr = _ARMV4_Status_irq_enable();
>     gpio01_19_high(); /* Signal High */
>     bsp_interrupt_handler_dispatch(vector);
>     gpio01_19_low(); /* Signal Low */
>     _ARMV4_Status_restore(psr);
>     cpuif->icceoir = icciar;
> When I check GPIO signal using digital scope, I can check average duty
> cycle.
> Do you think that it is good method ?
It depends on your needs.
> There is additional question.
> I think that CPU time percentage using "cpuuse" is CPU time consuming
> value except interrupt handler consuming time.
> Is it correct ?
No, the interrupt processing time counts as execution time of the
executing thread.
> Best Regards,
> Thomas
> 2018-01-12 15:03 GMT+09:00 Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>>:
>     On 12/01/18 02:38, Thomas Kim wrote:
>         Dear Sir,
>         As I checked until now, thread(task, pthread) cpu load
>         analysis method using "cpuuse" is perfect !
>         At this time, I am doing multiple device interrupt hander
>         stress testing. but, there is not CPU load anaysis method
>         about multiple device interrupt handler.
>         Is there any method for checking CPU load about multiple
>         device interrupt handlers ?
>     The is limited support for this. You can try to use enable the
>     profiling option:
>     cpukit/sapi/include/rtems/profiling.h
>     For interrupt profiling a BSP support is necessary. I think it is
>     only implemented on ARM, PowerPC and SPARC currently.
>     The RTEMS trace linker is also an option.
>     Sebastian Huber, embedded brains GmbH
>     Address : Dornierstr. 4, D-82178 Puchheim, Germany
>     Phone   : +49 89 189 47 41-16
>     Fax     : +49 89 189 47 41-09
>     E-Mail  : sebastian.huber at embedded-brains.de
>     PGP     : Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
