RSB fails to build QEMU
Rehab Massoud
rehab.massoud at gmail.com
Sun Jan 21 13:36:24 UTC 2018
Hi Stephan,
I think simply your problem is at the end of the attached file:
ERROR: glib-2.22 gthread-2.0 is required to compile QEMU.
You just need to install the library as it's named in your Linux
distribution. Probably when you pass this also, another library could be
missing and you will need to install it as well. On Qemu's website they're
mentioning these 2 libraries as requirements.
Best regards,
Rehab
On Jan 21, 2018 14:21, "Stephan Gambke" <s7eph4n at protonmail.com> wrote:
Hi.
I am new to this, so I am probably missing something obvious, but when I
try to build the qemu.bset RSB fails, giving me
error: building qemu-42d58e7c6760cb9c55627c28ae538e
27dcf2f144-x86_64-linux-gnu-1
Build FAILED
See error report: rsb-report-qemu-42d58e7c6760cb9c55627c28ae538e
27dcf2f144-x86_64-linux-gnu-1.txt
(The error report file is attached.)
Here is what I did (starting from $HOME):
$ mkdir -p development/rtems/sources
$ cd development/rtems/sources
$ git clone git://git.rtems.org/rtems-source-builder.git
$ cd rtems-source-builder/rtems/
$ ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/5
devel/qemu.bset
(Before the last step I went through the involved config files and
commented out the md5 hash checks.)
Did I miss anything?
Stephan
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20180121/b29011cd/attachment.html>
